Pro Press Copper Crimping Cordless Tools
   / Pro Press Copper Crimping Cordless Tools #22
In my area people used to have a lot of copper but switched to CPVC. I bought a 25 year old house with CPVC and after 6 CPVC cracks or leaks every few months I finally ripped it all out and PEXd it. I am a happy camper except for the fact I started to use brass PEX fittings which may or may not last, but don't know. The last half of the job I used PEX plastic which hopefully will last till I am pushing up daisies.
The brass pex fittings are a lot thicker than copper pipe is. I don’t see that you’re ever have any problems with the brass corroding through. I usually use plastic pex fittings because they’re cheaper and I’ve never had any problems using them either.
   / Pro Press Copper Crimping Cordless Tools #23
A few years ago, despite all the "use black pipe" crowds
warnings I put together a short run of pex for air lines.
I'll admit that I was skeptical but having worked with it and came across a few forum guys that had also used it and one that worked in a commercial situation where it was used, I ran about 30' of it to a couple of hose reels. It can't get direct sunlight and my nagging leaks are at a black pipe manifold I put together rather than the pex or the FIP fittings and copper band clamp. I think the negative feelings are a throwback from those who dared to use pvc "back then" for air systems.
I'm pretty well convinced that it's just fine for air lines and any additions that I might need in the future will be pex.
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
More info coming soon! (A56858)
More info coming...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A55853)
2005 Northwood...
Freightliner Tender Truck - Adams Tender (A55315)
Freightliner...
12' CONTAINER (A52706)
Informational Lot - Financing (A55315)
Informational Lot...
