Security & Theft Preventing Theft... Ideas Wanted...
/ Preventing Theft... Ideas Wanted... #1
Dave___in___CT
West-Central CT
Kubota L3130, LA723 Loader, BH90 Backhoe, Curtis Cab, || '82 Gravely 8199KT garden tractor
Hi...
What ways do you folks help protect your tractor and implements from being stolen... ? /forums/images/graemlins/confused.gif
Especially... if there is no secure building to put 'em in... and you are not near (miles away) where the equipment is...
Thanks...
Dave...
/ Preventing Theft... Ideas Wanted... #2
First, make sure you're insured against theft and vandalism (I'd worry more about vandals then thieves).
Make sure your machine is not obvious from the road or people passing by.
If you know the neighbors of the property you're keeping the tractor at...can you store it on their property? If not, can they keep an eye on it? Might be worthwhile to let the local law enforcement folks know you're storing your tractor there.
Pull the battery and put a chain (or bicyclist's type cable) through the steering wheel to a fixed part of the tractor. If you can get a locking fuel cap, do that.
None of this will prevent someone who really wants your tractor from taking it. None of this will prevent some lowlife from slashing your tires or other mischief. It might protect it from those "casual" thieves or vandals who don't want to work too hard at their crimes.
As far as the implements..same as for your tractor. Chain them together. That won't stop someone with a bolt cutter, but it might slow them down a bit.
I did have my 670 parked at a house I was selling (my previous abode) about 10 miles from my current residence. Fortunately, one of my former neighbors allowed me to park it in their fenced yard. I wasn't worried about theft, but was concerned one of the neighborhood kids would climb all over it...maybe hurt themselves.
/ Preventing Theft... Ideas Wanted... #3
I have my tractor locked up in a barn. So I can’t help much. But here is a thread that will lead to another thread on this subject.
Click Here
/ Preventing Theft... Ideas Wanted... #4
Fortunately for me, I have never had to worry about this as my tractors and other vehicles are stored in secured garages.
It goes without saying that the first line of defense it to have theft and vandalism coverage on your tractor, however, the fine print on most homeowners insurance policies limits your coverage to YOUR RESIDENCE PREMISES. If you are storing your tractor away from your home, check to be sure your equipment is covered.
As we all know ignition keys are very generic and while it will
be a pain to pull the battery in many tractors, doing so will certainly prevent theft of that item as well as reducing the odds of someone starting the tractor. On some models you can limit access to the engine and battery by wrapping a heavy cable around the underside and hood, but on my JD the front grille folds down to permit the battery to be stolen.
If I were really worried about theft I would remove the battery and then block up the front axle and remove one front wheel and take it with me. It would not deter someone who was a real professional but anything that slows down a crook will reduce the odds.
/ Preventing Theft... Ideas Wanted... #5
Hi
Removing the distributor cap might help.
Charlie
/ Preventing Theft... Ideas Wanted... #6
"Removing the distributor cap might help. "
True, if the tractor has a gasoline engine. Diesel engines don't have distributors.
However, that comment does bring up a thought. Someone seriously determined to steal a tractor would, most likely, trailer it out. It would be somewhat conspicuous seeing someone drive a tractor down the road. So, figure a way to make it tough to load the machine on a trailer. One end against a tree...block the other end in some way.
Another post mentioned pulling a wheel (front one would be the easiest). Well, that sure would prevent the tractor from moving under it's own power.
/ Preventing Theft... Ideas Wanted... #7
You may not like this suggestion. But I think one of the best you can do is make it invisible. Spend a couple of weekends and build a small polebarn. It doesn't have to be much. In fact, maybe the more dilapidated it looks, the less likely some A%#%hole will break into it. Then add one or more of the many suggestions you will get on this thread.
I remember a guy in high school add a switch plate under his dash. I think the ignition wires, or maybe fuel pump was wired through it. The plate had 5 switches on it that had to be switched in a certain order for contact.
Another idea might be to remove some fuses, or better yet, replace some fuses with burned out ones.
Solar powered alarm to alert neighbors?
Pet rattlesnakes?
Buy a trailer and bring it home with you?
Whatever you choose, good luck.
/ Preventing Theft... Ideas Wanted... #8
Coming from retired police chief, a thief has as many ways to steal your items as you have of preventing them from being stolen. You can never stop a thief if he or she wants something. All you can do is provide a deterant. If it is trailerable make it as hard to move as possible. If it can be carried make it as difficult to carry as possible. Make a thief work to steal your items. Put yourself in a thiefs position, ask yourself how would I steal this item and what deterrant could prevent it. A good insurance policy helps. Hope this helps. /forums/images/graemlins/smile.gif
/ Preventing Theft... Ideas Wanted... #9
We keep our tractor and implements at my inlaws' house, which is about 5 miles from our property. We trailer it up to the ridge when we want to use it up there. Maybe a neighbor will let you keep your tractor at his place?
Thanks for all the great useful advice... !
I do have physical loss/damage insurance on the tractor & implements...
...and they will be under cover of a soft sided structure...
I'll use the "disconnect a safety switch" idea...
...and a locked steel cable... maybe around the axle and connected to a buried concrete pier as my son suggested...
Also, ask the neighbor to keep an eye out... and maybe the police...
Removing a wheel or battery is too much work for me... ...maybe a battery disconnect or removing the battery ground (1 bolt) is a good idea so no one turns on the work lights...
Anyone have a source for a lockable gas cap ? /forums/images/graemlins/confused.gif
This is an excellent idea...
It's a screw on plastic one now... Kubota dosen't list one as an option...
Thanks...
Dave...
/ Preventing Theft... Ideas Wanted... #11
Pull the ignition fuse and put in a blown one.
/ Preventing Theft... Ideas Wanted... #12
Have you considered putting a Camoflague Tarp over the soft sided structure to conceal it from some of the casual viewers? This might help a lot if the structure is in/near a tree line. If they don't see the tractor/structure they are not likely to steal anything.
As far as a locking gas cap, try auto parts stores, or some of the discount auto parts cataloge companies.
/ Preventing Theft... Ideas Wanted... #13
My tractor won't be delivered for a couple more weeks, so these comments are theory, not practice, but I, too, am concerned and want to make a thief work for his loot.
Take a look at Kryptonite locks and accessories. A check of the Kryptonite web site shows lots of products that, while not specifically designed for tractors, may be of some benefit:
Kryptonite Locks
Check out the "Super StrongHold" for a buried attachment point to be used with a cable, but folds flat so you won't trip over it. I'm thinking that some of the U locks, such as the "New York 3000 MC" or "Adjustable Padlock" might be useable to restrain movement of hydraulic rams or to attach the backhoe to a stabilizer making movement awkward at best. A thief with a cutting torch can get through them, but you will slow him down.
If there is anyone nearby, consider attaching a battery operated door knob alarm. They probably will not do much good, but they don't cost much and if it starts making noise it might make a thief look for something easier.
/ Preventing Theft... Ideas Wanted... #14
Not sure what your soft sided structure is , but if it's one of those storage tents, you might consider erecting it over a lockable chainlink fence enclosure. They are pretty cheap. Of course, the only sure thing is a 24hr. armed guard.
/ Preventing Theft... Ideas Wanted... #15
Have you considered the Denver boot? It will stop most casual thieves, but more determined ones, might trash your tractor and set it on fire. Don't leave any filled gas cans near the tractor... Denver boot web page
/ Preventing Theft... Ideas Wanted... #16
Only one sure way. Set Arrnie out at the site with a lawn chair.
Egon
/ Preventing Theft... Ideas Wanted... #18
And that would be illegal in most states
/ Preventing Theft... Ideas Wanted... #19
And leave one very liable in a law suit!
That happened to a farmer in the Mid West many years ago. He rigged a 12 gauge booby trap. The guy (who had a lengthy criminal record) who was shot sued him and won a healthy settlement. Sure sounds tempting, but not a good idea...
2023 Mac Trailer T/A Walking Floor Trailer (A61568)
2023 Mac Trailer...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
1995 CATERPILLAR 938F WHEEL LOADER (A62129)
1995 CATERPILLAR...
New/Unused Electric Golf Cart (A61166)
New/Unused...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2022 New Holland C327 Compact Track Loader (A61307)
2022 New Holland...
