Premium Tractor Fluid from Costco
/ Premium Tractor Fluid from Costco #1
simmysam3
Spokane, WA
TYM 330 HST
Have seen a lot of discussion on fluids... even want to qualify against a previous thread I am not talking about their standard hydro fluid.
Costco carries a generic label product - called Premium Tractor Fluid. Claims to meet/exceed a variety of manufacturers requirements such as Deere or Kubota UDT. Being as costco is not brewing their own, what product actually lies within that big black bucket?
About to do my 50 hour change, and don't want to throw crap in it...
Sam
/ Premium Tractor Fluid from Costco #2
The place to start in that search usually is with the MSDS. Not sure if Costco has thiers online or not, but they will be available in the store, they must provide you one if you request it. Then start your sluething from there.
/ Premium Tractor Fluid from Costco #3
Sam
When I put the words "Premium" and "black bucket", it sounds like the same stuff that TSC sells...am I wrong? I've never seen it at COSTCO...How much are they asking for 5 gallons? BobG in VA
/ Premium Tractor Fluid from Costco #4
The Costco near us had AW-46 Hyd Oil for $26.89 / 5 gal. Not sure if AW-46 is adequate though for HST. Didn't see it advertised as "Premium Tractor Fluid", just Hydraulic Oil.
Nope, aw-46 is not it... thats a seperate bucket, and not what I was considering. Could not find the MSDS online. Will check next time I am in store, which is not too often.
/ Premium Tractor Fluid from Costco #6
Disregard my discussion of the AW-46 Hyd Oil. It's just plain hyd oil and not suitable for HST use.
/ Premium Tractor Fluid from Costco #7
I checked with one of the managers at my Costco several years ago about the lubricating fluids including the universal tractor lube and he said they were made by Citgo.
/ Premium Tractor Fluid from Costco #8
Holy Smoley! So what is it that is difference in the oil suitable for an HST. I had to add oil to my 330hst a while back and I think I used the aw-46 from Costco. %$#&!! Thats it..I was just considering changing it 2 weeks ago..but I think its a "like now" situation instead of doing what I like best....waiting till the snow is really deep!
/ Premium Tractor Fluid from Costco #9
What does the owners manual say for the fluid requirements? Hydraulic oils are blended for hydraulic systems only, not for use in tractor transmissions, tractor real axles and tractor hydraulic systems!
/ Premium Tractor Fluid from Costco #10
With Kubota's S UDT 2 selling for just over $100 for 5 gallons, I suspect it is a "better" product for HST uses. Posters who have installed it usually are pleased with the results.
Gear drive tractors should be fine with aw-46.
/ Premium Tractor Fluid from Costco #12
What does the owners manual say for the fluid requirements? Hydraulic oils are blended for hydraulic systems only, not for use in tractor transmissions, tractor real axles and tractor hydraulic systems![/QUOTE
Depends on your tractor.
And what do you mean by
Hydraulic oils are blended for hydraulic systems only, not for use in <snip> tractor hydraulic systems
Is that a typo?
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
Tow arm attachment (A64194)
Tow arm attachment...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
2022 EZ-GO ELITE...
