Pre-op Checklists
/ Pre-op Checklists #1
TomIre
College Grove, TN
Branson 3725
Just upgraded (to say the least) from an 8n to a new 3725 Branson diesel. With the 8n I'd do a circuit around the tractor and check oil (add oil, it burned a bit), attach battery cable (had a draining short somewhere), turn the fuel petcock on, check radiator level, check hydraulic level and all the while looking at tires and grease fittings.
Now with the new tractor I feel like it's more bullet proof and I wonder if all those checks are a bit ****! I don't check the oil in my car before heading home from work for instance.
What do you all do before and after operation in terms of checks?
/ Pre-op Checklists #2
I think checklists are great. I have been slowly assembling checklists for various equipment. It's so easy to overlook something small, but potentially important if you don't refer to a list.
/ Pre-op Checklists #3
I have an 8N as well and am looking to upgrade soon as well. Congrats on your new machine.
For the old tractor I'm more meticulous because there's a real threat that something is going to go wrong with it.
For my new John Deere X590 garden tractor, I just make sure to service it based on the maintenance schedule in the owners manual.
I should probably do a check list/walk around but the new stuff is so good it hardly seems to need much.
/ Pre-op Checklists #4
If you follow a checklist, you will never overlook the 'obvious' thing that will cause you great pain. A quick walk around will never hurt. You may not need to grease everything every time, but take a look at least. When I finish mowing, I park the GC1720 in the garage, pop and prop the hood so that the next time I return to it, I'm 'forced' to remember to clean the debris screen (now cool). And while I'm in there, I take a quick look at the coolant reservoir bottle, oil cap, check the dipstick and close the hood. It all take less than 2 minutes. I quick peak of the garage floor and I know whether anything is leaking or not.
Totally worth it to not blow it up.
/ Pre-op Checklists #5
Well you won't have to turn on the fuel petcock, or attach the battery anymore.
A quick walk around never hurts, looking for the obvious, leaks on ground, damage to tires or hyd hoses, etc. Also looking at the coolant reservoir and the fuel-water separator while finding the dipstick hole for the engine oil dipstick. I hit my grease fittings all the way around about once a month too, and that's really about it. Oh, and look at the hydro sight glass once in a while too.
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2005 Chevy 2500 Pickup Truck (A66408)
2005 Chevy 2500...
213091 (A64276)
213091 (A64276)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
