power tool recommendation
/ power tool recommendation #21
Honda makes pressure washers for sale in Japan. Honda America does not offer the units for sale in the US. In the US we have Honda Powered pressure washers made by different manufacturers.
It was a generic lowes/home depot unit with a honda motor.
The specs look good. I could not see the carb good enough to determine if it has a fuel shut off. I like this feature on a unit because we use the unit today and a year later we have use for it again. I turn the fuel off and let the unit run until it cuts itself off because of the lack of fuel. It is much easier to just tilt the unit over and pour stale gas out of the tank and not have to also remove and clean the carb.
Another feature the unit says it has is the use of “Chemicals And Detergents.” Most specify the use of pressure washer soap detergents only. It would be interesting to see exactly what chemical they are talking about.
See page 12 for starting/stopping,
The unit has a fuel "On - Off" setting. It also has an engine "On - Off" too. There's also a choke switch as well when it's cold, then move to "run" when she's cranking....
See page 14 for detergents - mainly emphasizes using only p-washer cleaning detergents and follow all instructions...
Thanks. I believe that Honda, Kohler and Briggs & Stratton make the most reliable engines. then it comes down to features and reliability.
I would concur that using only 100% gasoline w/out ethanol in it is the only way to go. Buc-ee's in our area sells corn-free fuel. I then add Marvel Mystery oil to all my fuels per spec...
/ power tool recommendation #25
I would concur that using only 100% gasoline w ethanol in it is the only way to go. Buc-ee's in our area sells corn-free fuel. I then add Marvel Mystery oil to all my fuels per spec...
I have a 2 year old troy built mower with a Briggs motor. Junk compared to what they were. Not a single metal part in the carburetor other than the jet. It's extremely cheap
But for $20 I cant complain
/ power tool recommendation #26
Good specs. The fuel shut off is great. The manufacture also recommends using 5-30 synthetic oil for all temperature ranges another plus factor. I think you have found a home use winner.
where I live and will use this, rarely ever below freezing for any extended period of time except extreme instances. I used 10W30, as in all my gasoline engines except my Ford 150; I use synthetic 5W30... Would you recommend this over the 10W-30 ?
/ power tool recommendation #28
I'm beginning to believe anything with a Honda motor on it is ok....
Every Honda engine I've ever had, the carburetor gets gunked up when it sits. And I always try to drain the gas out of the carb if I know it's gonna sit. And they never run right afterward. Surge all the time, hard (read; near impossible) to pull-start without throwing your back out .....very annoying
This is old information. They may have, and probably have, improved them.
If it's got another Internal Combustion engine on it, I avoid it if I can. If I can't........ them's the breaks
/ power tool recommendation #29
I like to follow the manufacturers recommendations. I also like synthetic oils in the winter time in small engines. Synthetic oil in my opinion also makes the unit easier for my old bones to start and provides better engine component protection during cold weather starts because the cold temperature flow rate is better than Dino oil.
Thanks gator !
By the way, i have a 1998 JD 4x4 gator. No extra features but a bumper guard and sprayed bed…here’s one of my faithful helpers..she was a great dog & great companion.
/ power tool recommendation #31
I have a Simpson pressure washer with a Honda GC motor on it. After a year the motor now drips oil. I doubt it had more than a couple hours on it when I noticed the puddle. I've had the same problems as Username. They sit for not very long and the carb has to be taken apart. My sawmill has a 2 cylinder Honda and I hate that thing. I finally got so fed up I replaced the carb on it with another Honda carb ($$$). Ran ok for a few months then sat. Doesn't matter if you run the fuel out or not they gunk up easily. My farm neighbor has a small engine shop and even he has apologized for not being able to get it running like new. So yes I don't share the Honda love.
/ power tool recommendation #32
Thanks gator !
I purchased the 6x4 for my late wife. She loved the flexibility it gave her in her flowers and other garden work. She really enjoyed the electric dump bed. I fixed her a dump area where she could dump clippings, limbs old vegetation etc. I would them take the loader and scoop it up and place on the burn pile.
Try adding some Marvel Mystery oil to all your fuel. I have tiller, riding lawn mower, push lawn mower, tiller, weed eater, 4 chainsaws, JD 4x4 Gator, 1951 JD MT, (had a power washer) & a 1996 M5400 Kubota (diesel). Only had to redo one carburetor on Stihl pole chainsaw.
I pour 2-3oz in 5gal gas container and fill it up…it really helps. At least it has for me. My oldest chainsaw i bought in 1995 & weedeater in 1994. All original still
/ power tool recommendation #34
I bought a Harbor Freight Predator 13hp model that I've had for about a year and have been very pleased with. I think it's rated around 4gpm 4000ish psi and you can turn the pressure down when needed. I had a lower pressure lower volume one at one point which doesn't even remotely hold a candle to this one. It actually pulls grease and paint spills out of your concrete and cleans your implements rather than acting like a high dollar hose nozzle for cleaning your Prius. It seems to have lots of good reviews but time will tell if it holds up
/ power tool recommendation #35
There is no magic engine to prevent a carburetor from gunking. I have experienced that with engines from, Clinton, Tecumseh, Briggs, Koehler, etc. I use sta-bil and Marvel Mystery in my small engine gas and diesel fuel.
Sta-Bil has this out now to help us with the gunking problem in the carb.
/ power tool recommendation #36
Seafoam works good for carb problems I also shut fuel off and run it til it dies. The pump is probably going to be your biggest failure point, less expensive pressure washers use cheap pumps in my experience. After my 2nd to last pressure washer I owned for a year, the pump failed again. So I researched a little went to Home Depot bought a DeWalt branded PW it came with a Honda GX engine and had a comet pump. 15 yrs later still running and operating good. Also you can actually change the oil in the pump which I do occasionally also has a sight glass for pump oil. So imo the pump quality is the biggest thing for durability on pressure washers.
/ power tool recommendation #37
Agreed, the only magic is converting to propane or using a diesel engine. But they both have their drawbacks. Propane makes less power in the same engine and requires a pressure tank & plumbing and a diesel weighs and costs twice as much for the power output.
In addition to the additives, I find that cutting the fuel and letting the engine run out of gas also helps by reducing the amount of fuel left in the bowl but does not entirely eliminate the issue
Thanks Jeff. As mentioned, I believe all products made 15-12 yrs ago are superior in quality to xxxx made today. What type of PW died after a year; make and model would be great to know to avoid. Also, how do you apply your seafoam? There's spray to the carb or liquid to fuel or other...thanks again
Thanka green. I believe the Marvel Mystery oil has lubricants in it for seals, o-rings and other...if I have not run one of my chainsaws or weedeaters for awhile, I just kill an ant bed.
/ power tool recommendation #40
I buy seafoam by the gallon, add about an ounce or two for every gallon of gas directly to gas tank. My other one was a inexpensive northern tool one Ironton brand I believe, had a sealed pump on a vertical shaft motor, super cheap you get what you pay for.
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2021 Ford F-750 Reefer Truck, VIN # 1FDWF7DE6MDF06465 (A65563)
2021 Ford F-750...
