Potato questions
/ Potato questions #21
Jim,
Do the potatoes have to have eyes to grow? I can't find any seed potatoes here in the city. In the past I've planted potatoes that had sprouted in the bag, but I'm behind this year and won't have enough time to wait for a bag to sprout.
/ Potato questions #22
DocHeb said:
Jim,
Chris, I think seed potatoes are generally more disease and fungus free than the potatoes you buy in bags at the store because they have been cured and in a dark and treated to encourage sprout formation from the eyes. I know I would not be happy to have to eat the potatoes I bought for seed potatoes because they looked pretty wrinkled and somewhat dry. If I could not find seed potatoes, I think I'd just buy a couple of bags of small potatoes, cut them in halves, cure them for 3-5 days, and plant them with the cut portion downward and about 4" deep. I think they will grow fine as long as your soil is not so wet that they rot. For normal temperatures and moisture conditions, I'd bet you will get good production. You'll just have to wait a week to 10 days longer to see sprouting. If you are like me, the anxiety of waiting for things to come up is a "killer."
/ Potato questions #23
Chuck52 said:
Unfortunately, the coon weren't discouraged by the fence and as soon as the corn started to get ripe the coons mowed it down. Chuck
Chuck,
I had the same problem, added electric fence and no more deer or coons. I usually wait for the first signs of damage and then put up the fence. How are the coons getting through your electric fence? How far off the ground do you keep your bottom strand? The peanut butter trick may seam harsh to some but it is quite effective.
Ray
/ Potato questions #24
Lats year my bottom rung was ~8" or slightly less in between so it was low enough to get rabbits/coon attention. that meant keeping weed eater around it a lot more as in centers of posts it was closer to 4" cat sure noticed it! lol. so did my brothers beagle's! (the dogs would go in and dig up the soft dirt like crazy! sure made woman mad as a hornet with a nest full of bear...) anyhow it was very effective on kitty, her tail would catch it when crossing under it hahaha. she got into it when we weren't home I guess as later when it was off we couldn't drag the cat near it!
I didn't try the peanut butter trick, but thought about it, the deer tore mine apart 2 or 3 times when getting bit they run into other side or crash through it as it seams.
2 years ago I didn't have a charger so I put up WHITE kite string all way around which was semi effective for the deer. so it is a easy fix to put up string if they are coming up chances are they know what a fence is and will stay away for a short period.
mark M
/ Potato questions
Ray,
My problem with the electric fence may just have been the charger. I wasn't close to electric, so I used a battery powered one that may not have had enough zap. I had wire down to a few inches off the ground, so a coon would have had to touch it, but I suspect they could get through by using their fur as an insulator since my charger wasn't thowing lightning bolts. The deer never even tried to get into that field, even after I turned off the charger when most of the corn was gone. As to the peanut butter trick being cruel...ah well, I've even considered getting some of those electric prods you stick in the ground near whatever you want to protect. They come with a bait to attract the deer, and zap them when they stick their nose/tongue on the bait. I'm afraid deer are just really large rats to me. If I see them on my property, even during the winter, I encourage them to go elsewhere. Too much tree and shrub damage for me to enjoy Bambi anymore.
Back to potatoes.....I checked under my pile of grass clippings and there are indeed taters under there! I think since I started with a layer of dirt, most of my potatoes will be under the dirt, but I felt a few poking out. Enough so I can noodle out a few to go with the green beans I'm picking now.
Chuck
2021 Bobcat E42 R2 Series (A60462)
2021 Bobcat E42 R2...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Eagle Weathervane (A55853)
Eagle Weathervane...
