Positioning new barn in relation to wind?
/ Positioning new barn in relation to wind? #1
dweitzel
SE, IN
Cub Cadet 7360SS
Getting ready to start a barn project this spring and wondering what is the best way to position the barn in relation to the wind direction. I'm on top of a ridge that sees some pretty hefty winds.
Pole barn 27' wide by 64' long, 18' side walls.
I'm thinking about positioning the corner of the barn into the wind. I realize that any good building will have plenty of wind bracing, but just wondering since I have the ability to position the barn pretty much how I want, is there any advantage putting the corner into the wind, short side or long side. Also, any insight on the roof and the wind would help also. I'm thinking about a standing seam if I can afford it.
Thanks. Dave
/ Positioning new barn in relation to wind? #2
I would also think about wind loads on doors - trying to open and close them during high winds could be a challenge. You may want to face the short side (gable) to the wind. Less surface area than the long side and less chance of lifting roofing material.
Is there a chance of planting a wind break later on - something that won't interfere with the movement of apparatus around the exterior building? Metal roofing (standing seam) would be great and if possible don't overlap the lengths - purchase full length panels to fit ridge to soffit.
We boarded in our roof prior to installing metal for the following reasons:
Stronger roof
Less noise with rain
Better surface to screw to and you can walk on roof if need be.
Stringer for snow loads
* out tar paper down to prevent rot from metal sweating.
Hope this helps.
lloyd
Thanks Lloyd, yes, if I go with standing seam, I'll have someone come and roll it full sheets on site. My truss mfg want me to put trusses 2' OC due to wind im my area and also for sissor trusses to get additional head room if I put in a loft or stalls later.
I'll probably put thin roll insulation under the metal roof to allow condensation to flow out the eaves rather than drip on the hay inside.
Any other wind ideas for the roof/attaching the roof? Thanks again
Dave
/ Positioning new barn in relation to wind? #4
I have dismantled metal roofs that were laid over plywood only to find then badly rusted on the underside.
Metal will sweat and when in contact with wood it will never dry, hence the rust/rot will start soon.(think like a wet sponge)
I think you want some air space there.
I would think that furring strips every 12" would be better than plywood (and cheaper) as that would allow for air dry.
Other than extreme humid conditions, with 12" furring you probably would not need insulation or vapor barriers.
Only with a snow load on roof in warm spring days do I see enough condensation to cause dripping around here.
/ Positioning new barn in relation to wind? #5
I would face small side with doors facing the wind.Plywood under metal is
good for added strength.Make sure you use 30# felt under. Framer
/ Positioning new barn in relation to wind? #6
be generous with your roofing nails/screws around the gable edges and dripline. hip roof is best design for prevalent high winds in all directions. constant downforce while the wind is passing over your roof.
Thanks for the replies. I'm pulling the permit on Friday and I will post pictures as I start the barn. Any other ideas, please post them.
/ Positioning new barn in relation to wind? #8
Not sure what your snow situation is like? I would personally avoid having any doors on the north side of the building. Any snow on that side of the building won't melt as fast as on the sides that have sun exposure.
Plus, the old northwest wind has a habit of finding any gaps in the door gaskets... then you have snowdrifts inside the building. :-(
Also, position your walk doors on the gable end of the building, if possible. It bites to have snow slide off the roof and land in front of the door.
My shop was built completely wrong - overhead door on the north side and walk door on the side. Won't do that again.
Sounds good, yes, the sliders and the gable end will be on primarily East/West sides. I plan on a drive through with a 12' tall x 10' wide door on each end. Saw other posts about the snow sliding off and blocking the doors. Good tip and thanks.
Wind seems to come from NW usually. Real bad storms come from SW. They moved my 18000 lb storage trailer about a foot a couple of years ago. Lost some of the biggest trees on my property. I know some of the trees were probably 200+ year od white oak trees.
Thanks again.
/ Positioning new barn in relation to wind? #10
What matters most is to have the building properly engineered,
Then it makes NO difference regarding the orientation.
Do not assume the contractor will put in adequate wind bracing.
Put it in writing and on the contract. The salesman will talk the talk, but the carpenters will not walk the walk. Communication is essential.
Good Luck,
Yooper Dave
Yes, eventually. Putting a 12" dia and a 8" dia phone pole in the same hole hoping to put a loft in someday. Also spec'd out sicissor trusses to get a little more headroom. Problem is spanning the 25+ feet clear w/no beams or posts in the middle. Think I have it figured out, but just need to come up with the materials. A few bales of hay can sure add up to a LOT of weight in a hurry. If I get around to it I'll post the pictures. Thanks.
/ Positioning new barn in relation to wind? #13
Dave
Re: roll insulation. I swear by the foil backed on both sides bubble wrap insulation under the roof tin over purlins. Cuts the sound from heavy rain too.
I had a 56x120x12 foot long barn in PA oriented E-W with most of my winds coming out of the NW down off of my hills. Closing the E 12h x 8w (16' overall) doors prior to opening the W doors helped on a windy day. The snow did build up on the E side particularly towards the SE corner.
During non windy summer days, the E end air got rather stagnent but at 64' in length, that would not be an issue.
I would box and vent the end eaves at least if not the sides of the roof. You can get long "U" shaped strips of metal that lay over your roof rafters or trusses then nail to the headers or posts to further secure the roof. If you use a double header with short pieces of 2x6, etc. nailed perpendicular inside of the headers rising up to then nail your trusses to, go up in size to a 4x6, etc. for more surface area to nail to. Or, take the time to secure 2x with screws. Pre-drill the upper area prior to fastening the truss/rafter to them. Better yet, run some screws in from both sides with pre-drilling the side you are going through first. Might want to take the time to fasten the roof purlins with screws also at least at the end eaves. Best to use a counter sinking bit to predrill the purlilns and set the screws a hair below the surface to allow for shrinkage. Insulating should help to prevent dimpling though.
Lastly, brace your corners with some steel diagonal strapping prior to nailing the horizontal purlins on.
Sounds great on the ideas. Looks like we are thinking the same on all the issues mentioned. I did spec the simpson hurricane straps I think you are talking about for tieing down the trusses. The metal wind bracing is a good idea.
Got a quote back yesterday metal. Got sticker shock on the metal. 29 ga, #1 metal for roof and sides over $6800, or more than half the material cost of the barn. This does not include the sliders for the doors, but is roofing, trim soffit and metal for sides. I think this is a pretty good bid from the pricing I've seen, but come on. Scrap is way down. Are the metal dealers trying to sell out their old high price stock first?
Any ideas. I'm in SE In if anyone has ideas for metal suppliers.
