Portable Generators
/ Portable Generators #102
Correct. You double the amperage not the voltage.
What if you set one on top of the other rather than side by side? Does that double the potential? :D
/ Portable Generators #105
Then explain EXACTLY how to do it, on two small Honda generators???
All the kits made to connect two inverter gen sets from the factory are parallel kits...
SR
A paralling kit doubles the amperage available.... It doesnt make a 120 gen operate at 240. If you had two 2,000 watt generators that each provided 16.6 amps of power @ 120 volts, by paralling them you can get 33.2 amps at 120 volts.
/ Portable Generators #106
<snip>
We also had an EU3000is, which got stolen from work. All moot as OP needs 240 for well pump.
Why bring up the OP - For a while I thought this was only about smog pollution and burning wood :)
OH!! The Original Poster:
Looking to get a portable gas generator, around 8,000 - 10,000 watt generator output. This will be to operate the well water pump during construction and some power tools. It will later be used as a backup power in case the main electric power goes out.
Been looking at Generac and Honda.
Generac XP8000E (clean power design for sensitive electronic equipment) - $2,400
NorthStar Honda - $2,300
Any other ideas, comments or recommendations?
Well if you can run the "sensitive electronic equipment" off a battery based UPS this might be a potential solution:
Duromax (which I wrote about WAY back in this thread) has their 10KW on sale again.
Go to ebay for DuroMax 10000 Watt Hybrid Dual Fuel Portable Gas Propane Generator .
And then apparently there is a coupon code C20LABORDAY for another $50 off.
Several of us on TBN have bought this over the last year or so since this thread and I can't remember any complaints.
/edit
It's been on sale a couple of times over the last year, normally for $699. I've one and it saved my son and his family of going to a motel when his power went out for days and we used it for hours off and on to run construction equipment.
$650 versus $2,300.
/ Portable Generators #107
Looks like it is around $1,000 now.
Read through the comments and many satisfied users.
Complaints I read were more about support or the noise rating being measured at 21' away.
/ Portable Generators #108
I wonder if today's appliances are "sensitive electronic equipment". The Generac write up makes a point of saying it is safe for appliances.
/ Portable Generators #109
Good question...
I buy UPS power supplies for work and most often the Uninterruptable Power Supplies Specified are Sine Wave Units which cost more than modified sine wave.
A manufacturers of sensitive medical equipment supply the UPS seeing it as critical.
All of the UPS units I install are connected to the facility Emergency Power Generator which typically provides power transfer in 6 seconds from power loss, generator start, load transfer... so these UPS units only bridge less than 10 seconds from loss of utility power to transfer plus they also provide voltage variation protection...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A59228)
2023 John Deere...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61307)
2006 Heil Tanker...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
