Portable garage
/ Portable garage #11
I've made a few of these. Pallets are generally free, the roofing sheeting was $26 each from Home Depot. 4x4x16 is $12.
/ Portable garage
Great ideas and pictures! I do like the Amish built idea and was toying around with building one myself. I have about 30 sheep so need it to be on the large size. I might just go with the portable garage idea for this year and tackle something more rugged next year. They’ll be back in the barn. Come November anyways.
/ Portable garage #13
Just don't build a kite. ;)
If there is no up-lift for wind, you have a secure shelter.
/ Portable garage #14
I had one of these for 15 years until I bent a pole hitting it with the tractor. That was also about the limit before seams started to rot and come apart. With the domed top, it easily shed snow, we had one storm were we got almost 3 ft of snow with some pretty good winds on the coast of Maine.... no issues.
They are better made than the Shelter Logic units, also a little more expensive. I used the cable anchors that came with the unit. Waste of time, use the screw-in anchors. I needed to move my unit, I just made up a wooden frame that attached to the center of the top of the unit that mated with the bucket on my tractor. I lifted the unit with the tractor and had a person at each corner guiding it. Once lifted, it took about 5 minutes to move it about 1000ft.
/ Portable garage #15
Thanks for the report. high winds and snow load are a big concern out my way.
/ Portable garage #17
I’ve had a shelter logic 20 ft garage in a box for about 6 years. I had to use the cable anchors because the rock a glacial till they call soil around here wouldn’t allow me to use screw in anchors. It’s survived blizzards and tropical storms in New England. They sell these things at tractor supply with a 7 oz cover to meet a low price point. Mine started leaking and tearing after 3 years. They offer replacement covers +14 oz pvc with 10 year warranty or a 21 oz with 15 year warranty. I got the 14 oz which was over $1000 which is more then the whole garage cost me.
/ Portable garage #18
I dont know if I can still dig up the pictures; but I had a free 8 ft diameter steel conduit spool, for holding 1"-4" communications conduit. I cut the two outside hoops in half, creating 4 half circles; the spreader pices of the inside of the reel are 4 ft long 1" steel square tube; i used those as "legs" and "purlions"; and spaced the 4 half circles at 4 ft OC; giving me an 8 ft wide; 8 ft tall; 16 ft long, steel frame; I then put some thin hat channel on at "roof" and hung a heavier duty, semi clear, nylon reinforced tarp over it. The hight at the side "walls" was 4 ft, and the center height is 8 ft. The tarp is long gone, and the frame is sitting in the woods still at the old house.
/ Portable garage #19
I'm not suggesting that you hunt down, and pay for a conduit spool, but more than I would see what you can rig up for next to free. The advantage of the metal frame, you can drag it around; I used hold galv street sign U channel as runners. It would sure beat assembling, and disassembling the soft sided tarp garages every couple weeks when you move pasture
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
(INOP) 2008 FORD F150 XL TRITON TRUCK (A59823)
(INOP) 2008 FORD...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
