eepete
Platinum Member
I cheated on the communication and video between my out buildings... I used fiber optics. Nonconductive.
What did you put in? Pointer to fiber and electronics would be great, tnx.
Pete
Pete
So Cyril, are you loosing copper to the tweakers or is this something more.
My video system set me back about $400 for 4 cameras, but none move, and I have to use webrowser. to view the respective house. No detail on any of the cameras, but the one guy we caught was working for a contractor whom was on the property. Easy find.
Carl
The transformer is about 500 to 600 feet away on the otherside of the property. see pic.Where does your electrical service come into your property relative to where you are planning this building?
In my case, the supply came up from the road roughly following the drive to house. When I had an existing pole barn and a new metal horse barn wired we excavated and tied into the supply line under ground* near the project. My electrician was concerned that if we came from the house and back to the new service there would be capacity problems. It also saved material and was a lot simpler job. He earned his money with me right there.
*The connection was made in a Traffic box.
Well my building will only be 250 feet from the house so I'm planning on dropping a couple of cat 5s for my network and cctv. I'm pretty sure they work upto 350 feet without a repeater.
Jim here's your answer. The 1993 NEC also required a 3 wire system to have a ground rod installed.
Thanks again 507 and Cyril..............Happy New Year to you both. Jim
Happy New Year Jim.
What is the picture in your avitar? I can't quite make it out, but it looks cool!
