Pole Barn Renovation
/ Pole Barn Renovation #12
Great job Kenny, pics of the project were appreciated. Love my barn, but it can't hold a candle to yours.
My two favorite places to hang out are my barn and any hardware store.
We've got a new Harbor Freight store coming soon. Could be dangerous (Shh, don't tell my wife.)
/ Pole Barn Renovation #14
Kenny,
Nice job and great looking shop. I am planning on putting a wood stove in mine now that it is complete. Your shop looks a lot bigger than mine, what is the sq ft, how much insulation do you have?
I may look for a wood furnace like I have in my basement if I can find one at a good price.
40 x 48 so about 2000 ft2 with a 12 foot ceiling. The walls have about 5 inches of polyiso foam and the ceiling has about 6 inches of cellulose blown in.
I only heat it when I'm working. If I don't heat it for a week with outside temperatures down to single digits outside, it will get below freezing in the building. Heat up with the wood stove is a little slow because of all the mass inside the building. I usually run a 70k BTU torpedo heater for 15 minutes or so while I start the wood fire and get it hot. Then I will be over 40 degrees and it creeps on up from there with the wood stove.
/ Pole Barn Renovation #16
Great job Kenny. That kind of work is extremely good for a man's Soul. :)
As to the wiring, yep, conduit is much easier. When I built mine I wired it for less money using steel conduit than it would have cost using normal wiring procedures.
Remodeling the interior of a building you've already moved into sucks doesn't it...... ;)
I think over time you will see that you need to blow in more ceiling insulation. At least 80% of your heat loss is thru the ceiling. 6" is marginal. My building is wrap insulated during construction with 6" faced fiberglass. Then I added a ceiling with another 8" of blow in. I added the blow in early this Winter. Made an instant difference. Should have done it during initial construction 5 years ago.
I heat with wood primarily. I have a fire every day that's needed. I feed the stove at 9p.m. and then start it again around 8a.m. I have a 100K btu propane furnace also. It's thermostat is set on 62 degrees. Last Winter I burned 70 gallons of propane. My shop never got below 62. I understand that you might not need a constant temp like that now. But in time you might. That is when the insulation will become a critical issue.
My building is 42x50 with a 12ft (at the peak) vaulted ceiling (10'5" at the eave). I light it with eight 4ft long 4 bulb T-8 fixtures. They are awesome and in 5 years I've not replaced any bulbs. I paid $97 each for the lights w/bulbs. If you ever decide to add light, check them out.
Great job Kenny. Thanks for posting this thread. Hard to not come away from a thread like this without picking up an idea or two!!!! :)
2006 Freightliner M2 HR46M Bucket Truck (A60352)
2006 Freightliner...
John Deere 7410 (A53317)
John Deere 7410...
2023 John Deere 325G (A60462)
2023 John Deere...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
John Deere 1025R (A53317)
John Deere 1025R...
