Pole Barn Question
/ Pole Barn Question #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I'm installing a third pole building on the property. The first two have concrete floors but the new one will be just dirt. This will be my first experience with dirt floor buildings and I'm curious what others do where the overhead doors touch the ground. We get significant frost heaving in the area, are there any tricks to closing the gap at the bottom of the door? Also, what is the best way to close the gap where the steel siding meets the ground?
/ Pole Barn Question #2
I don't know about the doors, my pole building doesn't have doors.
But the siding is easy. In most pole barns the poles are connected by horizontal runs of "2by" lumber...like 2x6s or whatever. You simply make the bottom horizontals from treated lumber. Fasten to the poles and let the lumber rest on the Then fasten the steel siding to that lumber skirt but a few inches off the ground.
/ Pole Barn Question #3
For the door, I'd excavate down to your frost level (and consider the sunlight it will see in the winter) then put in some 2"+/- crushed stone (no fines) for drainage. Then at about 12-16" below your finished grade lay in some 2" foam from post to post and 2' each way outward from the center line between the posts. This will help keep the frost out from under the stone
(4X8 sheets) then continue with the same or a little smaller stone that'll still drain well up to your door level. Having water draining away from this area is important.
For the steel/ground intersection, I'd keep the metal a minimum of 6" above the actual dirt and either drop down to the surrounding grade with PT (like you'd normally use for the bottom wall girt) or some will fill this with well draining crushed stone.
I like the PT lumber method, just be sure it's "ground contact" at minimum. "Direct burial" would be best.
I don't like having any wood contact the ground anymore. They've played with the preservatives so much that unless you can source "marine grade", (yes like in docks and piers) I don't trust it for much more than a mailbox post or a clothesline. 😆
/ Pole Barn Question #4
We just had a pole barn built not long ago, without a floor to start. Some 57's in the threshold were enough to keep us happy and the bigger critters out.
It now has a concrete floor, so... can't show a picture. The bottom 2x6's below the metal (PT) became the form boards for the slab.
/ Pole Barn Question #5
There isn't really a good way to do that with a dirt floor, unless it's sandy dirt. Graveling the floor would help.
The skirt boards (the bottom girts) should extend down below grade. If they don't, you can add more.
/ Pole Barn Question #6
Where I live frost lifting the poles is a very big issue.
So I had a slab poured and built on top of that using 2x6 studs. Built 34 years ago and the building is still perfectly straight, just wish it was bigger.
Have a friend that built a much bigger pole building, part of it has concrete floor, most of it has gravel floor, he installed conveyor belt all around the inside bottom boards in the gravel part to keep snow out and have a ability to little flex , it has worked very well for him, his building is about 5 years older than mine, he did put a new steel roof on it last year.
/ Pole Barn Question #7
I have a building with a gravel floor. I embedded 4x4 ground treated timbers under the doors. Works fine but I'm in an area with well drained sandy soil, so even when it freezes there isn't much ground heave.
My first barn was slab on grade construction to avoid the frost issue. I built it in 1988 and it has remained stable over the years. The second was a pole building with concrete floor built in 1990. The posts were set below the frost line and are also resting on ledge rock. It has also remained stable. The new pole barn will use the same post on ledge construction except without a concrete floor.
I will likely use this same idea with a thick layer of well drained gravel underneath the timbers.
/ Pole Barn Question #10
57’s?
/ Pole Barn Question #12
Use a rat guard under the steel on the walls. It fastens to the treated wall purlin before you side the building. Make sure it is as level as the terrain will allow. Its purpose is to narrow / close the gap created by the ribs bent into the steel siding. Or use a J channel
/ Pole Barn Question #14
57's are are a mix of screen 5 and screen 7 i.e. 3/4" to 1/2" with little to no fines, and usually washed so no dirt or excessive dust. Perfect for clean concrete.
/ Pole Barn Question #15
I put treated 4" X 6's under the doors. Dug a couple inches deeper than the 4 X 6, then wedged the timber up against the bottom of the track. I'd predrilled holes in the timber. Flooded sand under the timber and left it set a bit. Then drove re-bar stakes down through the timber and counter sunk them a bit to hold it in place. Keeps groundhogs and 'coon from digging under door too if you have any around. I did this 14 years ago, and everything is still in place.
I drive my tractor and manure spreader in and out one. Bobcat carrying hay in from the field another, tractors and horse trailers in and out the other 3. So far so good.
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
30 Yard Dumpster (A61166)
30 Yard Dumpster...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
Honda Rancher 300 es (A64047)
Honda Rancher 300...
2017 Case CX145D (A62177)
2017 Case CX145D...
