Pole Barn project
   / Pole Barn project #1
dustinfox
New Hampshire
Kioti CK35 HST
Does anyone know of a reputable pole barn builder servicing north central New Hampshire? I got a quote from a local guy for a 30x40 pole barn, gambrel truss roof, all wood, for $30K (that does not include any kind of floor or ground prep). Seems like a lot of money to me.
I'm guessing there can't be more than $8k or $10k in materials but I have no idea what a 30' gambrel truss would cost.
Any suggestions or guidance would be appreciated.
Thanks people :)
   / Pole Barn project
Anyone know what I could expect to pay for trusses?
   / Pole Barn project #3
2 years ago I paid around $100 for 32' trusses, but they were not ganbrel style. I had $10,500 into the materials for a 30'x50' pole barn-no gargage doors, no concrete, no electrical, but it did include 1' of overhang all the way around, with soffits and fascia, 2 man doors, and 7 2'x3' windows. Hope this helps.
Will
   / Pole Barn project #4
About 2years ago I had 32' gambrel trusses designed and estimated..
I believe they were around $150/each and they are 2'O.C. These were able to carry 40psf.
Wedge
   / Pole Barn project #5
Just for reference. The materials for my 40x60' pole barn not including the overhead door were around $18,000. No site work or concrete included. A local pole barn builder wanted $33,000 for the materials and to build it. My trusses are scissor trusses and they were close to $5,000 and include the purlins also. I am building it myself to save what money I can. Hope this helps.
Darren
   / Pole Barn project
Thanks everyone... this info helps. It reaffirms my suspicion that $30,000 is to much for a 30x40 pole barn. The guy who quoted me is a local builder whom we've used in the past. He does a good job and has always been reasonably priced. I think he may have decided that he wasn't charging enough for his labor.
I need to get more quotes but I can't seem to find anyone else in the area with experience building pole barns.
   / Pole Barn project #7
When I had my 30x40 barn built last year, I found the local builders were all the highest bidders. They all seem to overbuild as if the barn would be a residence.
One guy came in around $30k and when I finally got it through his head I only need a place to park tractor etc... he came down to $18k. I got a place that only does barns to do it for $15.5k.
   / Pole Barn project #8
Thanks people :)
That's 1200 square feet or $25/sq ft. I built this 20x28 ft = 480 sq ft equipment shed with metal roof and sides (29 ga R-panel) for about $3600 including gravel floor ($7.50/sq ft).
My 24x42 ft (1008 sq ft) all metal shop with 12 ft high walls cost $16K installed ($16/sq ft) in 2005 for the building alone including two 10x10 ft roll up doors. The concrete floor (6 inches thick, 4000 psi mix, #4 rebar on 24" centers) cost $8K installed.
So I'd say that bid you got is way high for what little you're getting.
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
