Plowing engine trouble
/ Plowing engine trouble
Just seen there is fuel coming out of 2 of the 3 lines coming out of the pump. They are tight any clues of the cause ? ImageUploadedByTapatalk1452714614.803268.jpg
/ Plowing engine trouble #22
is the sealing part deformed? i dont think this is why it would not start though?
It was low 30s. I guess it could have been doing that earlier. I have it in the garage now will be going out soon to see what is wrong with it.
That about when it died but it got probably 5 over the night
Got the Yanmar back together. Had to bleed the whole system. She fired up and went and plowed my huge driveway and it did great. I am loving this tractor.
/ Plowing engine trouble #27
Good to hear :thumbsup: I assume you have the winterizer in there??
While your at it....Has your antifreeze been changed or tested in a while?
Ah no winterizer. I will have to get some. Anti freeze is full don't know when the last time it was changed. I will have to do that to. Does it matter what kind of antifreeze I use?
/ Plowing engine trouble #30
As Todd8665 mentioned add the Power Service.
I would get in the practice of adding the Power Service in all fuel year round. It has other benefits and will help avoid this problem in the future.
Glad your running again.
Sure will! The fuel lines are not leaking any more either.
/ Plowing engine trouble #37
yep you have a water pump. Go with 50/50.
If you did not have one Todd is right you only want 25% antifreze or you will overheat as the thermosiphon wont work correctly.
2000 LUFKIN FL-II T/A  48FT FLATBED TRAILER (A59914)
2000 LUFKIN FL-II...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
