Plowing engine trouble
/ Plowing engine trouble
Just seen there is fuel coming out of 2 of the 3 lines coming out of the pump. They are tight any clues of the cause ? ImageUploadedByTapatalk1452714614.803268.jpg
/ Plowing engine trouble #22
is the sealing part deformed? i dont think this is why it would not start though?
It was low 30s. I guess it could have been doing that earlier. I have it in the garage now will be going out soon to see what is wrong with it.
That about when it died but it got probably 5 over the night
Got the Yanmar back together. Had to bleed the whole system. She fired up and went and plowed my huge driveway and it did great. I am loving this tractor.
/ Plowing engine trouble #27
Good to hear :thumbsup: I assume you have the winterizer in there??
While your at it....Has your antifreeze been changed or tested in a while?
Ah no winterizer. I will have to get some. Anti freeze is full don't know when the last time it was changed. I will have to do that to. Does it matter what kind of antifreeze I use?
/ Plowing engine trouble #30
As Todd8665 mentioned add the Power Service.
I would get in the practice of adding the Power Service in all fuel year round. It has other benefits and will help avoid this problem in the future.
Glad your running again.
Sure will! The fuel lines are not leaking any more either.
/ Plowing engine trouble #37
yep you have a water pump. Go with 50/50.
If you did not have one Todd is right you only want 25% antifreze or you will overheat as the thermosiphon wont work correctly.
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
1995 WILSON PACE SETTER DWH-400 HOPPER BOTTOM TRL (A64277)
1995 WILSON PACE...
Progressive Liquid Nitrogen Applicator (A66285)
Progressive Liquid...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
E-Ton Viper RXL-50 FOURWHEELER (A62613)
E-Ton Viper RXL-50...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
