Plowing engine trouble
/ Plowing engine trouble
Just seen there is fuel coming out of 2 of the 3 lines coming out of the pump. They are tight any clues of the cause ? ImageUploadedByTapatalk1452714614.803268.jpg
/ Plowing engine trouble #22
is the sealing part deformed? i dont think this is why it would not start though?
It was low 30s. I guess it could have been doing that earlier. I have it in the garage now will be going out soon to see what is wrong with it.
That about when it died but it got probably 5 over the night
Got the Yanmar back together. Had to bleed the whole system. She fired up and went and plowed my huge driveway and it did great. I am loving this tractor.
/ Plowing engine trouble #27
Good to hear :thumbsup: I assume you have the winterizer in there??
While your at it....Has your antifreeze been changed or tested in a while?
Ah no winterizer. I will have to get some. Anti freeze is full don't know when the last time it was changed. I will have to do that to. Does it matter what kind of antifreeze I use?
/ Plowing engine trouble #30
As Todd8665 mentioned add the Power Service.
I would get in the practice of adding the Power Service in all fuel year round. It has other benefits and will help avoid this problem in the future.
Glad your running again.
Sure will! The fuel lines are not leaking any more either.
/ Plowing engine trouble #37
yep you have a water pump. Go with 50/50.
If you did not have one Todd is right you only want 25% antifreze or you will overheat as the thermosiphon wont work correctly.
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Fertilizer Openers (A65640)
Fertilizer Openers...
5' Bush Hog (A62613)
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
