Snow Attachments Plow extender
/ Plow extender #1
bowhunter543
Wisconsin
John Deere 770
When there is a lot of snow, it will go over the top edge of my plow. Has someone installed an extender to the top of the plow to help roll the snow instead of falling over the top?:anyone:
If you have, what material did you use?
/ Plow extender #2
I've seen them on front snow plows made of steel or heavy rubber, but don't know how you would do it on the rear blade, you would have a section on each side? and not be able to reverse the blade.
The snow wouldn't roll very well through the frame of the rear blade, so it would pile up on one side and get hard to pull.
This is of course if you're talking about a rear blade? Going by your picture.
I've plowed many years and seen snow foils on front blades, I never felt I needed one myself though.
JB
/ Plow extender
JB
I thought if it was made from rubber or something similar, it might hang down enough to clear the frame.
/ Plow extender #4
Yeah, I see what you're saying. I have seen them like that, a stiff pc of rubber sticking straight forward, and could swing up if loaded.
Just not sure how well it work with a rear blade, should help some though.
Good luck, JB
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
Cattle Feeder (A65640)
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
Single Cedar Glider (A65583)
Single Cedar...
