Placement of doors in 40x60x14 workshop
   / Placement of doors in 40x60x14 workshop #41
For a post-frame workshop 40' wide, 60' long, and 14' tall, with two overheads doors, each with the dimension of 12' wide and 12' tall, what would be the best placement of the two overhead doors?
The bottom line for door placement is very dependent on how one is going to use the doors. My post frame workshop is a single 8x8 overhead door and since it's only used occasionally to bring in material, it's offset to a front corner where I can access it with my trailer. Folks using doors for vehicles will have different needs and for some, a "pull through" design is desirable if the property supports that. Put your doors where they make sense for your intended use as well as for how your property will support access to/from them. Your post frame builder will handle any engineering required for that placement once you specify it.
   / Placement of doors in 40x60x14 workshop #42
My garage, built by the previous homeowner, is a dream. Two large overhead doors on one end, and a smaller one on the side toward the opposite end. The two large doors are for the major things, cars/tractors/motorcycle...the end door for "shop" access, mowers, hand-held tools. It was a great plan; can't claim it as my own.
   / Placement of doors in 40x60x14 workshop #43
my shop is 48' X 72'... I installed another door on the left like the one on the far right (10x12) .. then the 14X12 and the 10X12 next to the regular door.. snow slides off each end, I still have to use the big blower on the front because we've gotten over 13' of snow in the past.. inside ceiling is 14', plus the storage area above that..
   / Placement of doors in 40x60x14 workshop #44
I have exactly the same size building- I went with a 12x16 single door on the gable end of the building. I did provision for another door adjacent to it should I decide to install another garage type door.View attachment 789670
   / Placement of doors in 40x60x14 workshop #45
Lots of great ideas !
My garage-shop has end doors and side doors, the side doors are a pain when it snows or rains, thankfully it has a nice overhang so that helps a little.
Every building and building site is different, I highly recommend listening to lots of opinions so hopefully you will be able to choose the best options for your situation and do it right the first time.
   / Placement of doors in 40x60x14 workshop #46
Door placement is personal choice depending on use and layout. I have a 40x60x14 with a 14x12 on long wall and 10x10 on west gable wall. Works well with layout. My advise would be to make doors as wide as possible as i am regretting only having 14’ wide door.I only use shop for automotive, and project tinkering, welding, and it seems narrow at times trying to get vehicles in and out if i have to turn to get in around something. Also Installing a door later would be very expensive , do it now. Good luck
   / Placement of doors in 40x60x14 workshop #47
I was going to put in 10x10 overhead doors and my buddy told me to do 12x10. I'm glad I listened to him.
   / Placement of doors in 40x60x14 workshop #48
I wanted only one door in my shed and it has been working out great.
It's 24 x 12
   / Placement of doors in 40x60x14 workshop #49
Have the same dimensions, suggest a 16’ height door offset one end and one 14’ door offset on opposite end.One personnel door and one window. Works for me great for resale in further. I have a interior second story with the 16’ structure.
   / Placement of doors in 40x60x14 workshop #50
12 feet wide is rather narrow. i would opt for a 14 and a 20 feet wide. you wont regret it. You will regret the 12 feet though.
And an entrance door of course.
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
New/Unused Quick Attach Wood Chipper (A57454)
New/Unused Quick...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59575)
2016 FREIGHTLINER...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
2025 J and C 6X12SA 12ft S/A Enclosed Trailer (A56859)
2025 J and C...
