PICTURES ONLY thread
/ PICTURES ONLY thread #341
A few weeks ago when I brought my R 4047 home
/ PICTURES ONLY thread #346
/ PICTURES ONLY thread #347
Busy fall, plowing field to rid alders. Cutting and collecting wood. Bush cutting field for neighbor. Adding 3" to back drag. Getting 7010 setup for winter.
Alder roots plow.jpgAdd 3 inches backdrag 2015.jpgBrush Cutting 2015.jpgCollecting Fire Wood Dec 2015.jpg
/ PICTURES ONLY thread #348
To wet to do anything, sitting in the house bored, so...
The wife cutting while I was going to the other farm,
Posted before, the beginning of a new horse pasture,
Spreading lime/waste mixture on the hay fields..
The ever present co-pilot,
/ PICTURES ONLY thread #349
Hi there
I recently bought an LS R4041 and made some add-ons like a 12,000lb winch and a front and back 400 watts total on bar lights, (not yet wired).
I like to know if any of this charge could overwhelm my 80amps AGM battery, and if that's the case, if I should add a 22 amp second battery kit
(XS Power XP750CK).
NOTE: All are not to run a the same time.
Thanks
/ PICTURES ONLY thread #350
Hi there I recently bought an LS R4041 and made some add-ons like a 12,000lb winch and a front and back 400 watts total on bar lights, (not yet wired). I like to know if any of this charge could overwhelm my 80amps AGM battery, and if that's the case, if I should add a 22 amp second battery kit (XS Power XP750CK). NOTE: All are not to run a the same time. Thanks
What is power requirements of the winch?
400 watts for LED Light bars? That's 33.4 amps. That's a lot of light? 4 x 48 watt LED lights will give you a lot of light and give you ability to point lights as you need. Light bars are over rated IMHO.
Sent from my iPad using TractorByNet
/ PICTURES ONLY thread #352
The winch amp draw could be from 85 to 300 at 5% duty cycle, (max 45 seconds).
The front bar light it's rated at 210 watts, the back bar at 90 watts, and the winch spot lights 2x48= 96watts.
/ PICTURES ONLY thread #353
1 HP = 746 watts
(HP x 746) / volts = amps
(5 HP x 746) /12 volts = 311 amps
/ PICTURES ONLY thread #355
Skids I don't know where you are from but where i am it's more like this kind of back to work!
/ PICTURES ONLY thread #356
Some pics from today's snow.
/ PICTURES ONLY thread #357
This picture may have been from that work day or a previous one I just can't remember. Less than a year ago that pasture was so overgrown with cedar and mesquite you couldn't even crawl through it. In the previous picture I lit the pile on a day that was probably a little too windy and way too dry but the county gave me permission so I went for it. What you see there is me waiting with a drink for the pile to get cool enough to mound it over and leave it for the night. That pile in question was still glowing red three nights later.
I live down here because my wife hates that white stuff in your picture.
/ PICTURES ONLY thread #358
Slingin sand and roto tilling to smooth up a yard with the new 4155HC!
/ PICTURES ONLY thread #359
Thought I would share. Enjoying the new LS and all of the info on this site.
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
generator trailer (A61569)
generator trailer...
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
