PICTURES ONLY thread
/ PICTURES ONLY thread #341
A few weeks ago when I brought my R 4047 home
/ PICTURES ONLY thread #346
/ PICTURES ONLY thread #347
Busy fall, plowing field to rid alders. Cutting and collecting wood. Bush cutting field for neighbor. Adding 3" to back drag. Getting 7010 setup for winter.
Alder roots plow.jpgAdd 3 inches backdrag 2015.jpgBrush Cutting 2015.jpgCollecting Fire Wood Dec 2015.jpg
/ PICTURES ONLY thread #348
To wet to do anything, sitting in the house bored, so...
The wife cutting while I was going to the other farm,
Posted before, the beginning of a new horse pasture,
Spreading lime/waste mixture on the hay fields..
The ever present co-pilot,
/ PICTURES ONLY thread #349
Hi there
I recently bought an LS R4041 and made some add-ons like a 12,000lb winch and a front and back 400 watts total on bar lights, (not yet wired).
I like to know if any of this charge could overwhelm my 80amps AGM battery, and if that's the case, if I should add a 22 amp second battery kit
(XS Power XP750CK).
NOTE: All are not to run a the same time.
Thanks
/ PICTURES ONLY thread #350
Hi there I recently bought an LS R4041 and made some add-ons like a 12,000lb winch and a front and back 400 watts total on bar lights, (not yet wired). I like to know if any of this charge could overwhelm my 80amps AGM battery, and if that's the case, if I should add a 22 amp second battery kit (XS Power XP750CK). NOTE: All are not to run a the same time. Thanks
What is power requirements of the winch?
400 watts for LED Light bars? That's 33.4 amps. That's a lot of light? 4 x 48 watt LED lights will give you a lot of light and give you ability to point lights as you need. Light bars are over rated IMHO.
Sent from my iPad using TractorByNet
/ PICTURES ONLY thread #352
The winch amp draw could be from 85 to 300 at 5% duty cycle, (max 45 seconds).
The front bar light it's rated at 210 watts, the back bar at 90 watts, and the winch spot lights 2x48= 96watts.
/ PICTURES ONLY thread #353
1 HP = 746 watts
(HP x 746) / volts = amps
(5 HP x 746) /12 volts = 311 amps
/ PICTURES ONLY thread #355
Skids I don't know where you are from but where i am it's more like this kind of back to work!
/ PICTURES ONLY thread #356
Some pics from today's snow.
/ PICTURES ONLY thread #357
This picture may have been from that work day or a previous one I just can't remember. Less than a year ago that pasture was so overgrown with cedar and mesquite you couldn't even crawl through it. In the previous picture I lit the pile on a day that was probably a little too windy and way too dry but the county gave me permission so I went for it. What you see there is me waiting with a drink for the pile to get cool enough to mound it over and leave it for the night. That pile in question was still glowing red three nights later.
I live down here because my wife hates that white stuff in your picture.
/ PICTURES ONLY thread #358
Slingin sand and roto tilling to smooth up a yard with the new 4155HC!
/ PICTURES ONLY thread #359
Thought I would share. Enjoying the new LS and all of the info on this site.
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
Gravity Flow Wagon (A64127)
Gravity Flow Wagon...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
