Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #5,682
Yesssssss! Hydraulic drive?
If you were asking me, Yes. I have a power pack on the back. The PTO turns a hydraulic pump.
The joy stick for the chute control..
/ Pictures of your snow weapons #5,683
Thankfully, years of ski bumming have left me well equipped in the wardrobe department. :laughing:
Snowmobile helmet is what I use to combat wind. No snow coating because I don't have a snowblower.
Just a blade, so no major amount of cleanup of equipment or my clothes when finished.
/ Pictures of your snow weapons #5,686
It was expensive but well worth it.
At one time i was going to add a loader mounted post hole digger run off of the powerpack, but anded up not doing it. I ended up finishing the fences with the old 3 point digger. Since i didnt use my hydraulic unit in summer, i ended up not adding oil cooler. The 10F weather keeps oil cool enough. I really am so glad i purchased the front blower. It has worked out so well for the past 9 years.
/ Pictures of your snow weapons #5,687
You've had that 4300 for a lot of years! I've been a member TBN since 2001...I've seen your attached picture (and your videos) many, many times!!
My 4400 with reverser transmission (open station) was my best tractor...the current 4052R may be one day...once I get some hours on it.
If we lived in a more temperate climate (Vermont winters are cold!!), I'd probably have kept it
/ Pictures of your snow weapons #5,689
I don't remember if I posted this before, I built it 3 years ago. It'll pull or push, most of the time I have it pushing. Where I need to back up against garage doors I'll turn it to pull so I can get close.
I can move snow with the front or back and hardly move an inch without one end or the other moving snow.
/ Pictures of your snow weapons #5,690
Nice setup for big snow. Do you use your quick attach carrier for any other implements?
/ Pictures of your snow weapons #5,691
cat fever: Very nice setup Lynn!
What size (diameter) hydraulic hoses run from your HP24 to your blower? Roughly how long are they? Does Erskine provide guidelines in their documentation?
Reason I ask is I have a older setup that was marketed to wood splitter users. It uses a 21 gpm Prince pump. I swapped out the valve for one intended for hydraulic motor direction control. I believe my lines might be a bit small.
/ Pictures of your snow weapons #5,694
Do I see three sets of attachment points for the back blade that you can offset to either side? And I think I see 2 sets of attacment point that you use for the push or pull option. Correct? Jon
/ Pictures of your snow weapons #5,695
5 Speed, that pic makes me shiver.
lol..that was a couple of years ago. I try to wait until the storm is over before I go out, makes it a bit more pleasant.
/ Pictures of your snow weapons #5,696
The ones mine use are 1 hoses
Thank you grsthegreat.
I have 21 gpm with 3/4" hoses. I think ideally I should have something like your 1" hoses.
Did the manual to your power unit have suggested sizes for the different flow rate pumps?
/ Pictures of your snow weapons #5,698
no, it came as a complete system. The pump puts out 3,000 psi as i recall.
/ Pictures of your snow weapons #5,699
Not able to off set it, and yes the "hooks" on the box mirror each other.
There's 3 of those hooks, then a vertical pair of 1" pins that drive down into a heavy wall pipe, otherwise it can swing by those hooks. I have a hydraulic top link that aids in the hooking/un hooking.
/ Pictures of your snow weapons #5,700
The Tach-all carrier is supposed to lock in via a lower pin. I don't see an attachment point on you Box. Do you just grab under the upper hooks and let the box pivot on that?
Tatch all carrier? Did I inadvertently copy something that exists?:laughing:
I'll post a picture of the linkage when I'm back on the computer.
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
HYDREMA 912HM ARTICULATING WATER TRUCK (A60429)
HYDREMA 912HM...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
1770 (A58375)
1770 (A58375)
UNUSED SDLANCH SDLL60 STAND ON SKID STEER (A60430)
UNUSED SDLANCH...
