pickup hitch problem
/ pickup hitch problem #1
rusty tractors
johndeere 2140
Hi i have a 2140 4WD and the pickup hitch bolts keep slackening off. and now one of the bolts well not tighten up i have put new bolts and washers in with lock tight i have even put fresh paint in them has any one else had the same problems they still keep coming loose thanks.
/ pickup hitch problem #2
pickup hitch?
is that like the 3pt lift arms?
based on what you describe i have NO idea what bolts you would be talking about.
Perhaps some pics?
FYI as it seems to be a question about your John Deere, the JD guys over in the JD forum might have a better idea.
and welcome to the forums.
/ pickup hitch problem #3
Welcome!
And, I can't figure out what bolts you are talking about, either... agree, need photo...then am sure you'll get good advice...you have done the typical things, so we need more information.
/ pickup hitch problem #4
I am with the others. I have no idea what you are talking about.
Chris
/ pickup hitch problem #7
Maybe this is a pick-up hitch?
The problem might be it's too high.
Hopefully OP has problem solved by now. :rolleyes:
/ pickup hitch problem #8
It sounds like he has a stripped thread in a casting, if it was a nut and bolt application replacing both would solve it. Unfortunately, locktite and paint are no substitute for threads, and the only solution will be to punch it out to the next oversize, or helicoil it if size is critical.
/ pickup hitch problem #9
5 year old post and the OP only made one post, so I'm guessing we will never know what he was talking about.
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
INGERSOLL RAND 80 GALLON COMPRESSOR (A65643)
INGERSOLL RAND 80...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
42" Hydraulic Smooth Lip Swivel Bucket (A62679)
42" Hydraulic...
