Photo Gallery problem
/ Photo Gallery problem #1
JerryG
Super Member
Northwest Arkansas
MF 1440-4 PowerShuttle
Ok, I sent two or maybe three e-mails to the administration about this problem over the last several weeks and never got any kind of response. Here is what is going on. If I click on to the Gallery tab at the top of the page, then click on My Gallery at the top of the next page. It takes me to a gallery that says that it's mine. It has only one picture which I put in back on Sept 17. The rest of my gallery is gone. Or I thought it was. I searched through the main gallery and found that my pictures were there. They even say that they are mine. At least until you click on the place where is says See This Users Gallery. Then is says this at the top of the page.
Home > Member Photo Galleries > Joem
I am clearly not Joem and I can't edit the gallery or change the owners name. Has anyone else had this problem?
/ Photo Gallery problem #2
Yes, lots of us have this problem and there is another whole thread about it, take a look at my signature? my gallery links, both of them :D
Jim
/ Photo Gallery problem #4
Willl said:
How 'bout we just change your name to Joem ?
J/K
And I suppose you want to change my name to DALE T
Wrong :D :D
J/K also
Jim
/ Photo Gallery problem #5
Curious,,,if ya don't hit the "Process Files" button after uploading, where do they end up going ?
/ Photo Gallery problem #6
Will, nice trailer in your gallery, did you build that and how long is it?
I was going to buy one like that from an ebay person but I found one closer and lots less money and wider and longer :D
Jim
/ Photo Gallery problem #8
Willl said:
Bought it from this place, did ya catch the jd pin striping ?
I was sitting down, It went right over my head, I'll stand up and it won't go over my head. :D :D
I had to go back and look hard
I think it was ( tims something ) in the carolinas. Did ya see mine in one of my gallerys
/ Photo Gallery problem #10
Jim
I'm slow but I didn't know that I was that slow. I have never seen the thread and didn't know anything about it. :(
Willl said:
How 'bout we just change your name to Joem ?J/K
From the sound of it, it might be easier to change my name than to fix the problem.
/ Photo Gallery problem #13
Can you edit/post pictures to the 'JerryG' gallery I linked to ?
If so, I'd copy the pics from Joem over to JerryG for now and let admin kill Joem..
/ Photo Gallery problem #14
No response to my e-mails or posts regarding these issues either and I realize that it is a "Free" site and you get what you pay for but someone is making some money somewhere. I also realize that DB issues can be complex but a reassuring e-mail or Posted Response by someone in ADMIN would be reassuring. If it were that simple, I would also change my log in to terradozer but would need the correct password to move them myself.
Someone who gives a **** in ADMIN PLEASE respond to :eek: these concerns
Thanks
/ Photo Gallery problem #15
I just tried and I can EDIT images in dale t 's gallery, the one in the first MY GALLERY ?
/ Photo Gallery problem #16
Will it allow you to move them back to your original gallery? My original gallery doesn't exist. I'll try the same - Thanks
but this is not a permanent fix :(
/ Photo Gallery problem #17
That doesn't work :( Tried to move a photo to my Gallery "4sarge" but only sent the photo to the black hole or back to terradozer. User numbers are crossed in the DB and I (we) do not have access to fix it. DB is either corrupted or update did not take successfully or was done incorrectly. Needs to be corrected but who knows if it will be :confused: Would be nice to hear something from someone in ADMIN :rolleyes:
/ Photo Gallery problem #18
What about just SAVE AS in your PC and UPLOAD it to TBN gallery?
or COPY and PASTE
I have seen lots of gallery problems with Vbulletin
/ Photo Gallery problem #19
or COPY and PASTE
There should be a "global fix" in the DB software to correct this problem. If you mean copy every photo then upload correctly then that would be very time consuming and still will not work because my user id 26***, assigned by TBN is cross referenced to terradozer and it's confused. What happens to you when the real DaleT deletes the photos that are not his or can anyone delete all of the photos if the edit function is used. Now that is a scary thought. I have all of the original photos on my PC. I uploaded them for the education and enjoyment of other TBN members.
/ Photo Gallery problem #20
I just did a search on my gallery owner and he has 3 post in 2006 in April and the last time he was on was a couple of months ago.
If my pictures get deleted like you mentioned, That will not even make my day :(
2007 FREIGHTLINER M2 4X2 S/A STAKE BED TRUCK (A59910)
2007 FREIGHTLINER...
2022 Timpte 1424 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1424...
Caterpillar TL1055D (A62177)
Caterpillar...
2023 Boxer 700HDX Compact Skid Steer (A63116)
2023 Boxer 700HDX...
2020 MACK GRANITE (A63569)
2020 MACK GRANITE...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
