Anyone else having problems viewing files?
/ Anyone else having problems viewing files? #81
What type of "corrupted file" stuck in a cache can cause images not to display?...including images in new posts??
CSS that is dynamically changing the image path to an invalid one (pointing at an old server, a invalid path, etc) on the fly, or not setting it at all? How to Set img src using CSS - Sabe.io
Troubleshooting 101 for browser issues is to clear the cache and cookies for the site in question, often followed by disabling add ons, why are you surprised that it would be suggested?
Aaron Z
/ Anyone else having problems viewing files? #82
Same here , can’t get images. Welding site images came through fine
/ Anyone else having problems viewing files? #83
I appreciate y'alls efforts. I've done enough troubleshooting for remote customers not know it is a thankless job.
For those having problems, it is often a both-and, not an either-or situation. If your OS or browser changed in some way it could affect something on how this site is viewed. While the Admins may be able to make a change that will fix it, finding the root problem is next to impossible. Patience and communication is key.
I think the fact that it has been narrowed to Safari speaks volumes to their efforts. I would use the workaround of using another browser for now.
/ Anyone else having problems viewing files? #84
Well - this morning is a totally different picture. I'm on FireFox and this particular thread is all screwed up. The thread opened up before all the data was loaded. Everything is listed in a vertical column on the left side of the page. Obviously there is work to be done here. I'll just say - adios - for now.
Strange - I checked five other threads on Rural Living - four were fine, one was not. AND now - about five minutes later - this thread seems to be OK.
I'm going over to Safari and see how that looks.
/ Anyone else having problems viewing files? #85
Here on Safari. Some avatars show - some do not. Same with the pictures. The messages show just fine using either browser. The answer for me - just use FireFox. And if FireFox goes "blink" - there are many others.
/ Anyone else having problems viewing files? #86
Aaron Z
I did nothing and now pictures are showing up on my PC running Windows 10 on a Surface PC. So, at least in my case, it either fixed itself magically or the problem was at TBN's end.
iPad is still not working.
/ Anyone else having problems viewing files? #87
When that happens, do you do an immediate refresh?
Sometimes network glitches (speed, switching, connectivity) can cause issues for page displays.
/ Anyone else having problems viewing files? #88
We didn't change anything. The safari browser issue has led us to some possible culprits but no reasons yet.
/ Anyone else having problems viewing files? #89
riptides An added factor in my case. I'm on HughesNet and have been experiencing varying degrees of connectivity - due to weather. Many, many years on HughesNet. I've learned - you take what you can get and work with it.
Refresh does help - sometimes. Booting up an alternate browser will solve the problems - sometimes.
When your ONLY IP is satellite - you learn to live with it.
/ Anyone else having problems viewing files? #90
Oh I completely understand. I am sometimes network challenged for both speed and connectivity. The browser is of course the first place I notice it, and usually with basic page displays that go wonky.
Today I am dealing with a PC that will not stay on a 5ghz network band. It looks like a driver update has been introduced and it decides at random time to speak more slowly than it is capable of. Incredible.
Good luck to you.
/ Anyone else having problems viewing files? #91
I’m using iPad through verizon jetpack, today everything seems to be working fine.
but definitely been having problems viewing pictures on and off since about Monday.
From my home out in the country verizon jetpack is often kinda slow but in Town where signal is stronger it usually works much better.
Must be frustrating for moderators dealing with some of the comments.
/ Anyone else having problems viewing files? #92
It's not just safari...still having the same issues...
/ Anyone else having problems viewing files? #93
Aaron Z
The CSS is on the server side...exactly how can it be dynamic ??
I was not surprised it was suggested...people often state the obvious...
BTW...I suggested it could possibly be a CSS issue early in the thread...
/ Anyone else having problems viewing files? #94
Something is still not working correctly. Here on HughesNet I still get - a weird initial log in page - a few avatars not showing - a few pictures not showing. Something has grabbed hold of TBN and giving it a good shake. My browser now is FireFox.
/ Anyone else having problems viewing files? #96
When I open a thread and get "weirdness" - close it - go back to main list of all threads - open the thread a second time - it's usually OK then. It's as though it takes two times to get all the info opened and in the correct place.
/ Anyone else having problems viewing files? #97
Recently I've been getting a lot of dead link image files using Safari
For example:
shows up with multiple dead image links showing empty placeholders on Safari but images render ok on FireFox.
sample dead image link in browser console
/ Anyone else having problems viewing files? #99
Here @ 11 pm - things are still not working correctly. Log in page opens with display of raw data. Same with many posts and no avatars. Looks very much like virus corruption.
/ Anyone else having problems viewing files? #100
I get that on occasion on Firefox on android, generally a reload fix is it, I'm assuming something isn't loading correctly with CSS as all the data is there, it's just not formatted correctly.
It can dynamically resize pictures to match your screen size, the site does that.
In theory, you could also have CSS set the current image location so that if the image hosting location changes as it has in the past old posts can be updated with the new image location and all the database needs to store is the unique attachment ID.
Looking at what is loaded for this particular page, I count 14 scripts and it appears to use 5 CSS style sheets with a total of 6,989 rules. It only takes a couple characters to getting changed for the whole thing to stop working.
That's because people often get complacent and skip the basic steps of troubleshooting, then act confused when their problem ends up being something basic.
How many threads have there been on here complaining about how their tractor won't start and it turns out to be either the PTO lever not being quite seated in neutral, on a hydrostatic tractor one of the pedals is just far enough out of the neutral position that it trips the safety and doesn't let it crank?
Why the complete and total dismissal of clearing cookies and cache as a troubleshooting step then?
If you've already done it great, say so. If you haven't you probably should.
Aaron Z
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2022 EZ-GO ELITE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
