PEX and floor drain
   / PEX and floor drain #11
Floor drains are a must. That's the beauty of PEX is its ease of installation. I just re-plumbed my entire house with PEX. Easy to work around anything.
   / PEX and floor drain #12
Like I stated in a previous post, here in Michigan, drains in outbuildings are a no, when the drain, drains directly outside. If it's tied into a sanitary system, that's ok. Interestingly, storm water can drain undergrouind and exit at a lower level. Grey water can't.
In my situation, I can't have any slope to the floor because I'm setting machinery on it. The floor was laser levelled during the pouring phase and power trowelled with an epoxy top coat.
My contractor thought I was wacky when I specified 8" of 6 bag mix until he looked in the other building and saw what I was going to set in the new building. It's important that the floor is stable and level as possible. When working in tenths, every little bit helps.
The building I added on to has floor drains (prior to the Michigan Law) with appropriate slope. It's a PITA to accurately level machinery in 2 planes with a floor that slopes.
If I was one of my motorcycles in the new shop in the winter with the PEX system running, a floor squeege to push the water out the door and 20 minutes later the floor is dry and clean.....
In retrospect, I should have run another zone under the parking pad and driveway to the building with a temperature controlled servo valve to keep the snow and ice melted off. It don't take a whole lot of heat/bru's to melt snow and ice.
   / PEX and floor drain #13
I have a floor drain that has a recessed ring around the outside to catch any oil drips etc. It can be cleaned prior to using the drain for washing. I wanted a floor drain for winter snow and in case i ever needed to wash the tractor in the winter. I am not sure a trap is a good idea. If the drain is not used a lot, that trap will start to smell.
Ken
   / PEX and floor drain #14
Ken
Pour some cooking oil in the drain, problem solved. I learned that one from a plumber.............
   / PEX and floor drain #15
Glycol solves traps evaporating dry. Doesn't cooking oil go bad over time?
Ken
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
MASSAGE CHAIR (A58214)
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
Landoll 876C Soil Finisher (A59814)
Landoll 876C Soil...
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
