plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,393
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I have been thinking along these lines. Although I've used the GPS in my Polaris for altitude measurement, I have doubts about its accuracy based on simply driving around and observing. I obtained a much higher quality GPS unit and will spend time tomorrow driving around and taking some samples at sprinkler risers where the pressure is also displayed.The water pressure will tell what elevation the top of the water in the pipes is located at. Each PSI of pressure is 2.31 ft of elevation.
Very close to the edge of my pond, I know that historically I should have about 42psi, and currently have only about 20psi. So about a 22psi shortfall. I had thought each foot of elevation was .43psi, but I will check that statistic for accuracy later.
I'm going to determine exact elevation at the pond pressure gauge tomorrow, then drive around the pasture at the elevation that would correspond to 22psi less. Probably mark the terrain as I do that. Then evaluate possible digging sites, sites to install shutoff valves, or where to listen to the pipes for flow due to leakage.
What this unfortunately presumes is the loss from leakage is equal to the replenishment from the supply. But after this amount of time, I'm going to presume it is somewhere close.
