plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 4,049
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
Somewhere, unknown, is a cracked or broken pipe compromising the pressure in my gravity irrigation system. The piping is 2 feet sub-grade, in well draining loamy soil, so water is not pooling anywhere on the surface. There are also some natural springs in the pastures. That is going to complicate any attempted repair once I find the crack or break.
I have no schematic but know the piping is installed like a Christmas tree-- a 4" main line going up the center, with 1 1/2" lateral lines going to sprinklers both left and right. The darker area in the center of the photo is where the 4" line is. Each lateral line has 3-4 sprinkler risers. I can sight along the risers and pretty well approximate the location of the lateral pipes. There are no shutoff valves. I'm pretty sure the crack or break was caused by an unexpected rapid draining that caused a vacuum to build.
My local rental yard has a pipe inspection device that goes 50' only, to fit in a 4" pipe. More likely I need something that can go 200 feet, with a camera and sonde transmitter, plus fit into a 1 1/2" pipe. Even with 200 ft reach, I'd have to work from both ends toward the middle.
Unless I can find the leak using equipment, I plan to first locate the 4" main pipe, then locate each junction where a lateral pipe connects, then install a ball valve shutoff on that lateral. Then keep repeating until I get pressure back.
At my lowest sprinkler location, I should have 42psi. Maximum I get now is only 20psi. I have used a stethoscope to listen at each sprinkler riser location, and based on what I hear I do have a guess of the general area, maybe also which lateral line might be leaking. But it's only a guess.
I'm not opposed to buying equipment to help find the leak. But $6,500 +/- for a one time repair is hard to justify. I've seen units for half that price but they don't get very good reviews-- plenty of failures of the cheaper units with no parts availability if they do fail.
Any ideas?
Any ideas?
