Equipment/strategies to locate a break in underground PVC piping?
/ Equipment/strategies to locate a break in underground PVC piping? #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
Somewhere, unknown, is a cracked or broken pipe compromising the pressure in my gravity irrigation system. The piping is 2 feet sub-grade, in well draining loamy soil, so water is not pooling anywhere on the surface. There are also some natural springs in the pastures. That is going to complicate any attempted repair once I find the crack or break.
I have no schematic but know the piping is installed like a Christmas tree-- a 4" main line going up the center, with 1 1/2" lateral lines going to sprinklers both left and right. The darker area in the center of the photo is where the 4" line is. Each lateral line has 3-4 sprinkler risers. I can sight along the risers and pretty well approximate the location of the lateral pipes. There are no shutoff valves. I'm pretty sure the crack or break was caused by an unexpected rapid draining that caused a vacuum to build.
My local rental yard has a pipe inspection device that goes 50' only, to fit in a 4" pipe. More likely I need something that can go 200 feet, with a camera and sonde transmitter, plus fit into a 1 1/2" pipe. Even with 200 ft reach, I'd have to work from both ends toward the middle.
Unless I can find the leak using equipment, I plan to first locate the 4" main pipe, then locate each junction where a lateral pipe connects, then install a ball valve shutoff on that lateral. Then keep repeating until I get pressure back.
At my lowest sprinkler location, I should have 42psi. Maximum I get now is only 20psi. I have used a stethoscope to listen at each sprinkler riser location, and based on what I hear I do have a guess of the general area, maybe also which lateral line might be leaking. But it's only a guess.
I'm not opposed to buying equipment to help find the leak. But $6,500 +/- for a one time repair is hard to justify. I've seen units for half that price but they don't get very good reviews-- plenty of failures of the cheaper units with no parts availability if they do fail.
Any ideas?
/ Equipment/strategies to locate a break in underground PVC piping? #2
I know some guy that borrowed an infrared camera from work and successfully located underground piping for a septic system.
/ Equipment/strategies to locate a break in underground PVC piping? #3
Put pressure on the start of that pipe and go start listening for leaks.
/ Equipment/strategies to locate a break in underground PVC piping? #4
We use a professional locating company to find broken underground pipes for our association water system. They used some machine that “bumped” or pulsated, the water in the pipes and a piece of equipment that could listen and find where the noise stopped, indicating leak zone. Only problem is, the bumping could theoretically cause other poor fittings to give way……
I considered pressurizing with an air compressor and listening for hissing and/or leaks, but it seems doing that is highly recommended. Something to do with making a bomb out of the pipe.
/ Equipment/strategies to locate a break in underground PVC piping? #6
They locate broken sewer lines by putting a lawnmower engine in a frame with a small prop that fits perfectly over the nearest manhole. They use industrial grade smoke bombs over the prop intake. Smoke will find its way to house sewer vents but also create a little wisp of smoke if there is a break underground. I saw it in action when I worked for an engineering firm doing a sewer survey. We did the locating and took notes comparing to the city's prints. A smoke crew came behind us a few days later.
/ Equipment/strategies to locate a break in underground PVC piping? #7
The water pressure will tell what elevation the top of the water in the pipes is located at. That will be some amount above the leak point, depending on how fast the water is flowing into the system vs flowing out through the leak. If you can cap off the inflows, the level will stabilize right at the leak elevation. From there you will need a transit or other way to accurately figure elevation. If the leak point is below the branch point, then you will know pretty exactly where the leak is located. If it's above the branch point, you won't know which branch has the leak, but you will know where to look on each.
Each PSI of pressure is 2.31 ft of elevation. You need to measure the water pressure as accurately as possible, so get a really good gauge, with a range as close to the expected pressure as possible. So if the pressure is around 15 psi, get a gauge with a range of 20-30 psi, not one that 100 psi. The calculated elevation is the height above wherever you are measuring the pressure. And note that it's the vertical elevation of the leak, not the length down the pipe.
Depending on the distances involved, another way you could do it is with a long hose. Connect one end to an outlet in your irrigation system, and drag the other end of the hose up the waterline. Crack open the hose valve and work your way up and down the pipeline path looking for where the water stops coming out of the hose. Right where the water stops flowing out of the hose is the elevation of your leak.
/ Equipment/strategies to locate a break in underground PVC piping? #8
I hired a leak detection guy from fifty miles away and it was worth it. He charged the system with helium.
/ Equipment/strategies to locate a break in underground PVC piping? #9
I did this several times for work, I did entire towns. I don’t think smoke testing would work in pipes this small.
/ Equipment/strategies to locate a break in underground PVC piping? #10
Wait until you are having a dry spell.
Watch how the grass grows green at the leak. ;-)/
The water pressure will tell what elevation the top of the water in the pipes is located at. Each PSI of pressure is 2.31 ft of elevation.
I have been thinking along these lines. Although I've used the GPS in my Polaris for altitude measurement, I have doubts about its accuracy based on simply driving around and observing. I obtained a much higher quality GPS unit and will spend time tomorrow driving around and taking some samples at sprinkler risers where the pressure is also displayed.
Very close to the edge of my pond, I know that historically I should have about 42psi, and currently have only about 20psi. So about a 22psi shortfall. I had thought each foot of elevation was .43psi, but I will check that statistic for accuracy later.
I'm going to determine exact elevation at the pond pressure gauge tomorrow, then drive around the pasture at the elevation that would correspond to 22psi less. Probably mark the terrain as I do that. Then evaluate possible digging sites, sites to install shutoff valves, or where to listen to the pipes for flow due to leakage.
What this unfortunately presumes is the loss from leakage is equal to the replenishment from the supply. But after this amount of time, I'm going to presume it is somewhere close.
/ Equipment/strategies to locate a break in underground PVC piping? #12
We were doing a chunk of Oklahoma City out near Lake Hefner. He said a 4" main with 1.5" laterals. getting the smoke into a small pipe would be interesting. I wasn't on the smoke crew but we sometimes overlapped in a couple areas.
/ Equipment/strategies to locate a break in underground PVC piping? #13
A GPS won't be very accurate. If you can string a small hose, it will be exact. A surveyor's total station would be accurate too, but probably not worth the trouble to get ahold of one, learn it, etc,, or to hire someone. A couple hundred feet of hose wouldn't be very expensive, I don't think.
/ Equipment/strategies to locate a break in underground PVC piping? #14
The phone app Gaia is quite accurate from my uses.
It depends on How many position sources it receives.
/ Equipment/strategies to locate a break in underground PVC piping? #15
Usually consumer grade gps isn’t going to be that accurate for elevations. Elevations is always going to be the weak point of gps.
/ Equipment/strategies to locate a break in underground PVC piping? #16
Not a real good solution. You won’t get water to the surface until the area is totally saturated. Water follows gravity first and goes down. When all the bottom is saturated it will begin to go laterally and then finally to thesurface
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
159120 (A60430)
159120 (A60430)
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59904)
2016 INTERNATIONAL...
Volvo L45H (A61306)
Volvo L45H (A61306)
KBH Tender (A61307)
KBH Tender (A61307)
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
