Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #701
I've had great luck with Pat's, on both my tractors. Yeah, you need to check the tightness of the bolts periodically.
I'll continue using them. Certainly makes hookup easier.
   / Pat's Easy Change System - Order Online! #702
a regular quick hitch is tons easier to use that the Pats, and you don't have to get off the tractor to use it
   / Pat's Easy Change System - Order Online! #703
   / Pat's Easy Change System - Order Online! #704
Agreed. They both have their good and bad points, you just have to decide which you would sooner deal with. I don't have the "pat's" but I have my home made version that worked exactly the same. The part I didn't like was having to play around with the spreader bar for the lift arms. It was a pain and I still had to get off the tractor to attach the top link. I bought a QH and have been happy ever since. Everyones opinion and needs are different, hence the reason for different designs. Both the pat's and the standard QH are great systems and make impliment hook ups easier, I just like the QH better.
   / Pat's Easy Change System - Order Online! #705
Dang. I just learned that Pat's has discontinued the "Slide-In" model.
I was excited about getting a set of them. :.(
Price dropped for Black Friday to $144.95 on the cat 1 standard and similar discounts on all other models. We will run this price through Tuesday. Price will go up next year for sure, we've been told.
   / Pat's Easy Change System - Order Online! #707
Is it possible to purchase replacement springs for this hitch? I got my hitch a couple of years ago and have busted both springs. Thanks!
   / Pat's Easy Change System - Order Online! #708
I broke springs twice, call them up and let them know. I got mine for free but that was a while ago...
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
