Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #701
I've had great luck with Pat's, on both my tractors. Yeah, you need to check the tightness of the bolts periodically.
I'll continue using them. Certainly makes hookup easier.
   / Pat's Easy Change System - Order Online! #702
a regular quick hitch is tons easier to use that the Pats, and you don't have to get off the tractor to use it
   / Pat's Easy Change System - Order Online! #703
   / Pat's Easy Change System - Order Online! #704
Agreed. They both have their good and bad points, you just have to decide which you would sooner deal with. I don't have the "pat's" but I have my home made version that worked exactly the same. The part I didn't like was having to play around with the spreader bar for the lift arms. It was a pain and I still had to get off the tractor to attach the top link. I bought a QH and have been happy ever since. Everyones opinion and needs are different, hence the reason for different designs. Both the pat's and the standard QH are great systems and make impliment hook ups easier, I just like the QH better.
   / Pat's Easy Change System - Order Online! #705
Dang. I just learned that Pat's has discontinued the "Slide-In" model.
I was excited about getting a set of them. :.(
Price dropped for Black Friday to $144.95 on the cat 1 standard and similar discounts on all other models. We will run this price through Tuesday. Price will go up next year for sure, we've been told.
   / Pat's Easy Change System - Order Online! #707
Is it possible to purchase replacement springs for this hitch? I got my hitch a couple of years ago and have busted both springs. Thanks!
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
