Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #641
You are the Man! I hope it wasn't a long walk...unless you needed it, like I do. Thank you for your reply and effort.
Glad to be of assistance! Take care.
   / Pat's Easy Change System - Order Online! #642
I bought the Pats at ASI and it came complete with spacer bar. Now it is so easy to change attachments on my own, they are wonderful
   / Pat's Easy Change System - Order Online! #643
Just joined, who is ASI? Also, I assume that a Kubota L3000 DT is a Cat1 hitch. Thanks in advance.
   / Pat's Easy Change System - Order Online! #645
Ok, I'm back. It's been a while since I installed the Pat's Easy Change but I only recently used my rotary cutter with it. I'm really liking the system as it does make changing implements much easier. Here's the deal tho; with the rotary cutter it seems the pto shaft on the cutter may be about to come loose. Where can I find an extension for the drive shaft and what would it be called. My thanks in advance.
   / Pat's Easy Change System - Order Online! #646
I had the same issue so this is what I just ordered. Pto Adapter The pic is wrong, but description is right. Haven't got it yet, will let you know when I do
   / Pat's Easy Change System - Order Online! #647
Actually, I think the photo is correct. I own two of them. They work perfectly and make up for the longer PTO requirement that the Pat's causes.
   / Pat's Easy Change System - Order Online! #648
You have a better pic than I do because when I bring it up it shows a six spline to a 21 spline, but describes a 6 x 6
   / Pat's Easy Change System - Order Online! #649
If you have a TSC (tractorsupplycompany) near you, they have the extensions that work.
   / Pat's Easy Change System - Order Online! #650
Yeah, thanks guys. The pic shown (6x21) is the same as the one I found at TSC, which won't work for me. I do need the 6 to 6. TSC didn't have that one. Now that I know there is such an animal I will ask them to order me one. Thanks again.
(2) 4"x30' NYLON STRAPS W/RATCHETS (A52708)
(2) 4"x30' NYLON...
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
1999 FORD F-150 TRUCK (A52708)
1999 FORD F-150...
202480 (A54757)
202480 (A54757)
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
40006 (A55788)
40006 (A55788)
