Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #641
You are the Man! I hope it wasn't a long walk...unless you needed it, like I do. Thank you for your reply and effort.
Glad to be of assistance! Take care.
   / Pat's Easy Change System - Order Online! #642
I bought the Pats at ASI and it came complete with spacer bar. Now it is so easy to change attachments on my own, they are wonderful
   / Pat's Easy Change System - Order Online! #643
Just joined, who is ASI? Also, I assume that a Kubota L3000 DT is a Cat1 hitch. Thanks in advance.
   / Pat's Easy Change System - Order Online! #645
Ok, I'm back. It's been a while since I installed the Pat's Easy Change but I only recently used my rotary cutter with it. I'm really liking the system as it does make changing implements much easier. Here's the deal tho; with the rotary cutter it seems the pto shaft on the cutter may be about to come loose. Where can I find an extension for the drive shaft and what would it be called. My thanks in advance.
   / Pat's Easy Change System - Order Online! #646
I had the same issue so this is what I just ordered. Pto Adapter The pic is wrong, but description is right. Haven't got it yet, will let you know when I do
   / Pat's Easy Change System - Order Online! #647
Actually, I think the photo is correct. I own two of them. They work perfectly and make up for the longer PTO requirement that the Pat's causes.
   / Pat's Easy Change System - Order Online! #648
You have a better pic than I do because when I bring it up it shows a six spline to a 21 spline, but describes a 6 x 6
   / Pat's Easy Change System - Order Online! #649
If you have a TSC (tractorsupplycompany) near you, they have the extensions that work.
   / Pat's Easy Change System - Order Online! #650
Yeah, thanks guys. The pic shown (6x21) is the same as the one I found at TSC, which won't work for me. I do need the 6 to 6. TSC didn't have that one. Now that I know there is such an animal I will ask them to order me one. Thanks again.
2019 International MV607 Cab and Chassis Truck (A56858)
2019 International...
New/Unused AGT Industrial MX-MRW14 Mini Tired Skid Steer (A57453)
New/Unused AGT...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
2023 Chevrolet Silverado 5500HD AutoCrane 6006EH 3 Ton Mechanics Crane Truck (A55973)
2023 Chevrolet...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
