Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #221
Hey Pat or anyone that may know. Will they fit the Kubota BX2350 with cat. 1? thanks Harry
   / Pat's Easy Change System - Order Online! #222
Harry,
Yes, they work great on the BX series. Just let us know, we have modified the receiver for a better fit.
   / Pat's Easy Change System - Order Online! #223
Does anyone have any experience with the weld on Pat's Easy Change?
I have a Kubota B2620 and am wondering how much longer the arms would be with the weld on unit.
Also, will I have a problem with slightly different hitch width on my implements as the Pat"s will not be adjustable for this.
Thanks,
B2620
   / Pat's Easy Change System - Order Online! #224
Check out the pictures of a weld on unit. They don't add any length to your arms and are still just as adjustable.
   / Pat's Easy Change System - Order Online! #226
I too have a Kubota 2620. I am wondering what the install intails or if its easy for someone w/o a lot of expirence to do?
   / Pat's Easy Change System - Order Online! #227
Charlton John,
Takes about 30 minutes for the initial installation. Just slide the receiver over the lift arms, decide which shims work best on your arms, slide back on and tighten set screws and install u-bolt. That is pretty much the the install.
The previous pictures are for the weld on units. Some customers have the balls worn out on their arms and just want to cut them off and weld on the hitches.
   / Pat's Easy Change System - Order Online! #228
Charlton John,
Thanks Pat, Are the shims included or something I will fabricate? Also is there anything special needed for my model? New model for 08 Kubota 2620. I have also been recently looking at this Delta system and need to decide (yours or theres) which one will be best for me, I am leaning towards yours at the moment, thanks again!
   / Pat's Easy Change System - Order Online! #229
All hardware, including shims, are included. The 2620 shouldn't be a problem. They have worked great with all the Kubota models. I do have a model with a short receiver for the BX series, because of the severe turn in the arms right at the ball.
   / Pat's Easy Change System - Order Online! #230
Thanks Pat, My arms dont seem to short but again I am also no tractor expert. Will I need these shorter versions for my 2620? Thanks
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
