Pat's Easy Change Pat's Easy Change System - Order Online!
/ Pat's Easy Change System - Order Online! #541
Well instead of reading the last 540 posts I'll just ask it here -
For an M4700 with Cat 2 link ends, presently using bushings to hook to Cat 1 equipment, I'm thinking I should get the System Type:Cat 2 w/Stabilizer Bar and continue to use bushings.
Am I correct? I envision some Cat 2 linkage in my future.
thanks
/ Pat's Easy Change System - Order Online! #542
thanks
That'll work.
/ Pat's Easy Change System - Order Online! #543
thanks
Ordered it, received it, have 1 complaint -
NO PACKING LIST!
The box was handed to my son at the door and one end was torn open. My son was being an air-head and didn't look at the box, just put it on the floor.
It seems there was nothing missing but on further opening the box I saw the plastic bag with "small parts" was also torn.
A simple printed parts list in the instructions would have gone a long way to reassuring me.
/ Pat's Easy Change System - Order Online! #544
NO PACKING LIST!
They are just a small operation, call them up and give them the message you left here. They'll appreciate hearing your complaint - from you. They are good people, trying to make a living off a good product.
If I were to rag on anyone, it would be about Kubota not putting this on my brand new $50,000 tractor to make my life easier!
/ Pat's Easy Change System - Order Online! #545
Mine arrived similarly. Everything was there and in good condition but a little better packing would be a good idea.
/ Pat's Easy Change System - Order Online! #546
It's not worth my time and I expect they can read it here.
And furthermore how come the instructions come in only 1 language? And there aren't two pages of safety warnings telling me not to swallow it or drop it on my toe? :)
They must have redone the instructions because the steps I read were extremely easy to understand and the only difficulty I envision is getting my tiller (that's on the tractor now) OFF so I can put the PEC on for the first time.
/ Pat's Easy Change System - Order Online! #547
Re: Pat\'s Easy Change System - Order Online!
Could anyone tell me what category I should get for my John Deere 2510 Diesel? The 3pt hitch is listed as cat II/I on tractordata.com. Does that mean it can take either? I inherited the tractor and know very little about them yet. My 2 attempts so far at changing implements were long and unpleasant. I'm hoping the easy change system will improve that. any help will be appreciated. Thanks, Gabe
/ Pat's Easy Change System - Order Online! #548
Is it currently Cat 1 smaller or the larger Cat 2 pin/hole size?
/ Pat's Easy Change System - Order Online! #549
To order Pat's Easy Change through TractorByNet, is there a coupon code or anything?
Some of the posts said they got free shipping......... Just checking before I place an order.
/ Pat's Easy Change System - Order Online! #550
Measure your balls, 7/8" hole is cat 1
Hitch Models
/ Pat's Easy Change System - Order Online! #551
I'd like to order the CAT2 Slide Ins for a M7040 but I see no way of ordering from here, nor the Cat 2 Weld Ons. I guess I have to go directly to Pat.
Can I tell him I'm a member and you sent me?
Richard
Greetings,
Some of you may have read about Pat's Easy Change System in past threads... and if you haven't, I've included some links to those threads below.
But first, I'd like to announce that we are now offering Pat's Easy Change System direct to TractorByNet.com visitors...
https://www.imcuniverse.com/store/easychange.htm
Click Here to Order Now!
That link contains a complete description of the system, user reviews, and pricing.
Regards,
/ Pat's Easy Change System - Order Online! #552
I called in and they were awesome to work with there. Top notch folks.
Richard
Richard
/ Pat's Easy Change System - Order Online! #553
Richard
Glad to hear they have not changed from when I bought a few years ago. :)
/ Pat's Easy Change System - Order Online! #554
Received my Pat's Easy Change last week. Works great. Only item I'm not so sure of is the "Optional" spreader bar.
I did order it. However, I now find that I have to remove it for any implement at uses the PTO, as it's in the way.
Since all my implements have a spread of about 26 inches maybe I didn't need to spent the extra $30. Guess I could of just adjusted
my chain links to keep the draw bars spread to that width. This is no knock on the Easy Change. I do like it!
/ Pat's Easy Change System - Order Online! #555
I use my on a Kubota B3200 that I upgraded to using telescoping links. Those links make it quick and easy to change the spread.
When I got the set two of the spring clip washers had the spring clip hole punched off-center. All it took was an e-mail and Vicky had three pairs in the mail at no charge.
Great product - Great service!
/ Pat's Easy Change System - Order Online! #556
Richard
If you click on the link in the quote it should take you to store.tractorbynet.com/pats-easy-change-p/ecs.htm and there is a drop down menu for options where you can choose Cat 2 standard. I don't see a weld on option.
/ Pat's Easy Change System - Order Online! #557
Will the CAT 2 Easy change system fit a 1960 IH B275 with stock lower arms?
Anybody already put a set on their B275?
Bart D. Hull
Laveen, AZ
/ Pat's Easy Change System - Order Online! #558
Just ordered the easy change for my M6040 Kubota. Do I need to remove the telescoping ends before installing?
/ Pat's Easy Change System - Order Online! #559
I have the Pat's system on one of my older tractors. I would prefer telescoping arms to Pat's.
/ Pat's Easy Change System - Order Online! #560
Wow, It looks soooo easy for this one man operation. Maybe I don't need them.
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
MASSAGE CHAIR (A58214)
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
