Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #551
Re: Pat\'s Easy Change System - Order Online!
I'd like to order the CAT2 Slide Ins for a M7040 but I see no way of ordering from here, nor the Cat 2 Weld Ons. I guess I have to go directly to Pat.
Can I tell him I'm a member and you sent me?
Richard
Greetings,
Some of you may have read about Pat's Easy Change System in past threads... and if you haven't, I've included some links to those threads below.
But first, I'd like to announce that we are now offering Pat's Easy Change System direct to TractorByNet.com visitors...
https://www.imcuniverse.com/store/easychange.htm
Click Here to Order Now!
That link contains a complete description of the system, user reviews, and pricing.
Regards,
   / Pat's Easy Change System - Order Online! #552
I called in and they were awesome to work with there. Top notch folks.
Richard
Richard
   / Pat's Easy Change System - Order Online! #553
Richard
Glad to hear they have not changed from when I bought a few years ago. :)
   / Pat's Easy Change System - Order Online! #554
Received my Pat's Easy Change last week. Works great. Only item I'm not so sure of is the "Optional" spreader bar.
I did order it. However, I now find that I have to remove it for any implement at uses the PTO, as it's in the way.
Since all my implements have a spread of about 26 inches maybe I didn't need to spent the extra $30. Guess I could of just adjusted
my chain links to keep the draw bars spread to that width. This is no knock on the Easy Change. I do like it!
   / Pat's Easy Change System - Order Online! #555
I use my on a Kubota B3200 that I upgraded to using telescoping links. Those links make it quick and easy to change the spread.
When I got the set two of the spring clip washers had the spring clip hole punched off-center. All it took was an e-mail and Vicky had three pairs in the mail at no charge.
Great product - Great service!
   / Pat's Easy Change System - Order Online! #556
Richard
If you click on the link in the quote it should take you to store.tractorbynet.com/pats-easy-change-p/ecs.htm and there is a drop down menu for options where you can choose Cat 2 standard. I don't see a weld on option.
   / Pat's Easy Change System - Order Online! #557
Will the CAT 2 Easy change system fit a 1960 IH B275 with stock lower arms?
Anybody already put a set on their B275?
Thanks
Bart D. Hull
Laveen, AZ
   / Pat's Easy Change System - Order Online! #558
Just ordered the easy change for my M6040 Kubota. Do I need to remove the telescoping ends before installing?
   / Pat's Easy Change System - Order Online! #559
I have the Pat's system on one of my older tractors. I would prefer telescoping arms to Pat's.
   / Pat's Easy Change System - Order Online! #560
Wow, It looks soooo easy for this one man operation. Maybe I don't need them.
2021 Honda Pioneer 4x4 Utility Cart (A56857)
2021 Honda Pioneer...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
(5) CANDY JARS (A58374)
(5) CANDY JARS...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
FEED WAGON (A52708)
FEED WAGON (A52708)
