Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #571
I put it on yesterday and went to move my disc to a different part of the barn. Hook up was a snap, BUT, now the top link is too short to reach the top connection on the disc with the extra length added.
I can't see any way to correct it without buying a longer top link, which doesn't thrill me.
Anyone else have this problem?
That is correct, you will need a longer top link. I wish they warned people of that better. I knew of it but I had extra top links around from old larger tractors so it wasn't an issue to me.
   / Pat's Easy Change System - Order Online! #572
VERY annoying. I even called and talked with them and no mention. I'm definitely not happy about it.
   / Pat's Easy Change System - Order Online! #573
Re: Pat\'s Easy Change System - Order Online!
I have an older case 1320 but my arms are 3.75" not the maximum 3.25" How much play is there? Can I stll slide the easy hitch on?
   / Pat's Easy Change System - Order Online! #574
We put the Cat 2 version on our MF 265 and the old top link was still plenty long but it was an after market version so they went with more range option to fit more things.
   / Pat's Easy Change System - Order Online! #575
I have a Kubota L5450. I'm not sure if it is a cat 1 or cat 2, trying to order Pat's quick connect.
   / Pat's Easy Change System - Order Online! #576
Want to take advantage of the season special but want to confirm this will work for a 1953 Ford Jubilee and figure out which model I should order? Thank you!
I just ordered one and found the same Pat's for $1 more at Agri Supply but it includes the spreader bar that is $25 from these folks! I am also concerned because my order does not show the shipping address which is different from the billing address. No one to call to make sure this goes to Montana and not Washington State. Tried to respond to order conformation "E" Mail but no response so far.
The model Agri Supply sells is different. It's an economy model, not the standard Pat's Easy Change system.
The e-mail confirmation is simply for the payment; the shipping address is in your order (I just checked).
The 1953 Ford Jubilee has a category 1 3-point hitch.
   / Pat's Easy Change System - Order Online! #579
Any comment on not telling people their top links may end up too short?
   / Pat's Easy Change System - Order Online! #580
Also tell them they will like the extra space due longer the longer arms when connecting like the bush hog, etc PTO shafts. If a PTO shaft or top link is already on the short side one may have to address that but if you know you can check both before you order to see if they have a few inches to spare in length.
We just went from bush hog to box blade for the winter and the son and I still get excited about having Pat's ECS. :)
2017 Ford F-550 Chipper Truck (A56858)
2017 Ford F-550...
2022 Delta Gooseneck Equipment Trailer VIN # 4MWGF4022PN059238 (A57453)
2022 Delta...
SIMIRON SV3 HD VACUUM (A58374)
SIMIRON SV3 HD...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
Portable Restroom (A54865)
Portable Restroom...
