Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #531
Well, after FOURTEEN YEARS - I have removed Pat's quick change from my 4100....
Had to.
I am putting them on my new 3032e !!
It's a shame that many implements aren't built as strong - Well Done Pat !
   / Pat's Easy Change System - Order Online! #532
Had to.
   / Pat's Easy Change System - Order Online! #533
WOW!!
   / Pat's Easy Change System - Order Online! #534
I need a set of 221's for my New Holland tn75s to convert from cat 2 to cat 1 since all the implements I need to change out are cat 1. I don't see 221's listed. Do I need to order direct from Pat?? Would like to give the business to TBN. Please let me know. Thanks
   / Pat's Easy Change System - Order Online! #535
Well worth the money. I can now change inplements in less then 5 minutes instead of 15-30 minutes.:thumbsup:
   / Pat's Easy Change System - Order Online! #536
Received Pat's Easy Change System today. Took my RFM off the tractor and had the thing installed in about 45 minutes.. If I did it again it would take about half that. Very Simple to install, a little tricky to plumb on the 3pt arms, but I love it already. Put on the Box blade in about five minutes, and was out doing some road repairs for a couple hours. Took off the box blade and put on the back blade to do the final smoothing over, again in about five minutes, and darkness ended today's playtime.
From what I"ve seen so far, I would recommend this to anyone who has cause to switch implements on a regular basis. It will make winters easier for me because I would like to switch between the back blade and the 3pt blower depending on the type of snowstorm and how deep it is. I would expect that this will make it possible. I wouldn't have considered switching back and forth without it.
In summer, the RFM is on about 90% of the time, but I do sometimes use the back blade or box blade or post hole digger, so it will come in very handy.
Sorry, I didn't see that TBN sells them. Got mine from Nothern via Amazon.
   / Pat's Easy Change System - Order Online! #537
We do have the 221s in our store. You select the option for category 2 -> category 1 from the drop-down box for options when viewing the product page. It's $13 more. Pat's Easy Change System - TractorByNet.com Store
   / Pat's Easy Change System - Order Online! #539
I bought a cat 2 system last year, and just got around to installing it last week. Installation took me at least 30 minutes... Now that I know how it installs, it would take 5-10 minutes if I were to do it again. Let me say that this is the single best purchase I have made for a tractor. I recently bought a 10' lift type rotary cutter that is a MONSTER. There is almost no way that I could easily hook it up by myself in a reasonable amount of time. The Pat's Easy Change System changed that. As soon as I had it installed on my tractor I backed up to the rotary cutter, dropped the lift arms, backed into position, and raised the arms attaching the cutter to the tractor! All done from the seat of the tractor! I hopped down and attached the top link and pto shaft, and was on my way in about 2-3 minutes WITH NO STRAINING OR HEAVY LIFTING! Easy to install, easy to use, built to last. If I ever buy a second tractor it will definitely be wearing a Pat's Easy Change System!
Amsaff
Mahindra 5530
   / Pat's Easy Change System - Order Online! #540
I have been using a 2x4 to line stuff up but I think this will be nice, so I ordered it today. Now I wish there was an easy way to hook up the shaft to the PTO.
2281 (A58376)
2281 (A58376)
2002 Toyota Camry LE (A57148)
2002 Toyota Camry...
48" Skid Steer Pallet Fork Attachment, Asset# 66 (A59076)
48" Skid Steer...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
1758 (A58375)
1758 (A58375)
