Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #541
Well instead of reading the last 540 posts I'll just ask it here -
For an M4700 with Cat 2 link ends, presently using bushings to hook to Cat 1 equipment, I'm thinking I should get the System Type:Cat 2 w/Stabilizer Bar and continue to use bushings.
Am I correct? I envision some Cat 2 linkage in my future.
thanks
   / Pat's Easy Change System - Order Online! #542
thanks
That'll work.
   / Pat's Easy Change System - Order Online! #543
thanks
Ordered it, received it, have 1 complaint -
NO PACKING LIST!
The box was handed to my son at the door and one end was torn open. My son was being an air-head and didn't look at the box, just put it on the floor.
It seems there was nothing missing but on further opening the box I saw the plastic bag with "small parts" was also torn.
A simple printed parts list in the instructions would have gone a long way to reassuring me.
   / Pat's Easy Change System - Order Online! #544
NO PACKING LIST!
They are just a small operation, call them up and give them the message you left here. They'll appreciate hearing your complaint - from you. They are good people, trying to make a living off a good product.
If I were to rag on anyone, it would be about Kubota not putting this on my brand new $50,000 tractor to make my life easier!
   / Pat's Easy Change System - Order Online! #545
Mine arrived similarly. Everything was there and in good condition but a little better packing would be a good idea.
   / Pat's Easy Change System - Order Online! #546
It's not worth my time and I expect they can read it here.
And furthermore how come the instructions come in only 1 language? And there aren't two pages of safety warnings telling me not to swallow it or drop it on my toe? :)
They must have redone the instructions because the steps I read were extremely easy to understand and the only difficulty I envision is getting my tiller (that's on the tractor now) OFF so I can put the PEC on for the first time.
   / Pat's Easy Change System - Order Online! #547
Re: Pat\'s Easy Change System - Order Online!
Could anyone tell me what category I should get for my John Deere 2510 Diesel? The 3pt hitch is listed as cat II/I on tractordata.com. Does that mean it can take either? I inherited the tractor and know very little about them yet. My 2 attempts so far at changing implements were long and unpleasant. I'm hoping the easy change system will improve that. any help will be appreciated. Thanks, Gabe
   / Pat's Easy Change System - Order Online! #548
Is it currently Cat 1 smaller or the larger Cat 2 pin/hole size?
   / Pat's Easy Change System - Order Online! #549
To order Pat's Easy Change through TractorByNet, is there a coupon code or anything?
Some of the posts said they got free shipping......... Just checking before I place an order.
Thanks
   / Pat's Easy Change System - Order Online! #550
Measure your balls, 7/8" hole is cat 1
Hitch Models
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
Giyi Mini Auger (A57149)
Giyi Mini Auger...
METAL FLIP TOP 9 DRAWER TOOL BOX (A58374)
METAL FLIP TOP 9...
2395 (A58376)
2395 (A58376)
2225 (A58376)
2225 (A58376)
2001 B&G Low Boy Semi Trailer (A57148)
2001 B&G Low Boy...
