Parts for heating
/ Parts for heating #1
FMFProperties
Ben Wheeler, Texas
Branson 4520C & Massey 1533
My tractor tried to get hot but thankfully it was the clogged radiator fins, all good now.
/ Parts for heating #2
Well, Kukje used to make engines for Cummins, so there's a chance. Unfortunately, that's about where my knowledge ends.
This presumes you have done the basics. Usually it is a radiator screen problem.
You decided it was the gasket, but 2 of 3 'tests' don't indicate that.
Hopefully, someone with more skills will weigh-in.
BTW, I have a version of the same engine.
/ Parts for heating #4
That's what the mobile mechanic determined because in order to start it, I have to pump the fuel pedal many many times while at the same time cracking the engine until it coughs and shakes then starts, all while still holding the starter on and pumping the fuel pedal. Se he says it's leaking and getting air in through the head gasket making it so hard to start.
That may be good info for our Kukje experts.
/ Parts for heating
It was the clogged radiator fins, all good now.
/ Parts for heating #6
@Asteral worked (may still work) for Big Tex in Caddo Mills. He's a wealth of knowledge on this stuff.
@ptsg is a bit further away (Portugal), but also has a great deal of knowledge, too.
@K5lwq is also nearby and has experience with Branson equipment.
/ Parts for heating
/ Parts for heating #8
This is one of those things where one will only know for sure if one is willing to spend the money on getting the parts need for a Cummins engine, then test fit them on the Kukje engine.
Otherwise, I don't think anyone will 100% garante that it will or will not work.
I've eyeballed the water pumps before for a A1700, only looking at pictures. Looked very very similar but then again, I didn't actually tested it on the engine, since it was just pictures.
/ Parts for heating
/ Parts for heating #10
I don't under stand how pumping the "gas" pedal is doing anything. It does not have an accelerator pump as a carbureted gas engine would have.
/ Parts for heating #11
"This is one of those things where one will only know for sure if one is willing to spend the money on getting the parts need for a Cummins engine, then test fit them on the Kukje engine."
Thanks. I'm sure I'm not the first person to ask this and hopefully someone has already tested the Cummings parts on their Kutje. That's who I'm hoping reads and answers here to clear up the doubt.
You're definitely not the first one to ask. It's actually fairly common question. Fairly legit too given how similar the engines are.
Unfortunately I don't recall if anyone here in the forum as went as far as that, or at least gave any feedback if they tried it.
/ Parts for heating #12
I would suggest sticking with TYM for the gasket and make sure they have your serial number. Some of the gaskets will look similar and would probably work if you carefully inspect the journal cutouts. They were a little different spots depending on models and you don’t want to block one with the gasket.
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
2005 little wonder high output blower (A64557)
2005 little wonder...
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
1024 (A63111)
1024 (A63111)
2017 Nissan Altima Sedan (A66738)
2017 Nissan Altima...
