Parked trailer safety tip.
/ Parked trailer safety tip. #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
I got to thinking as I dropped my gooseneck trailer today that I should pass along something that I do.
I have a five gallon bucket with holes drilled into it that I hang over the hitch to make it much more visible especially to kids. I hang the bale over the safety pin the roll the bucket under the drop tube. The fit is just a bit snug and the hitch ends up just inside of the top of the bucket. Should someone run into it, the bucket will likely hurt a lot less than that hard steel.
/ Parked trailer safety tip. #2
I do the same thing. I also have a tendency to walk across the yard at night without a light. I ve walked into a hitch and the ramps to. I have a yellow hydraulic oil bucket with a slot cut into it to fit over the hitch to be visible in moon light. It also helps keep wasps out. I was drivine around the lay down yard in my truck and bumped the hitch one time to.
/ Parked trailer safety tip. #3
I do the same thing with all my bumper pull trialers. Just use a bungee cord to secure it. I use cheap $1 2 gallon buckets from Walmart. It has also keep mine and the kids cloths free of grease and grime.
Chris
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
76in. Low Side Skeleton Skid Steer Bucket (A65640)
76in. Low Side...
