bdhsfz6
Elite Member
- Joined
- Apr 11, 2015
- Messages
- 3,980
- Location
- Northeastern Pennsylvania
- Tractor
- Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
As I get older, I find it more and more difficult to mount & remove implements. Over the years, I've used various tricks to ease the process. I palletized all my implements and installed heavy duty casters on the pallets to be able to move them around in the barn. I use the FEL forks to put them in position, and the casters to roll the final few inches up to the tractor. The problem is, the barn is getting too crowded with implements to be able to maneuver the tractor to pick them up with the forks. Yeah, I know, I need a bigger barn and another tractor but that isn't in the cards right now.
As a result, I find myself rolling the palletized implements around manually. This wasn't an issue a few years ago but now, with my bad back & joints, it's a real problem. I switched from moving the pallets with the FEL forks to a pallet jack. This helped a bit but it still takes more effort than I'm capable of sometimes.
I considered a powered pallet jack but they were heavy, bulky and expensive. Lately, I've been seeing these newer, lighter, more compact and reasonably priced jacks powered by lithium batteries. I'm considering this one from Apollo:
www.apolloliftus.com
Has anyone had any experience with these relatively new jacks? The specs are impressive and what reviews I can find are favorable, but it seems a lot to expect from an $1800 jack.
3300lbs Fully Electric Walkie Powered Pallet Jack with Lithium Battery
Powered navigation for urban deliveries, small markets and limited stock areas. 10 seconds to change battery reduces downtime. Push-button lift control and forward/reverse thumb wheels on handle. 4-6 hours service per charge. 3 hour charge time. It may vary depending on the usage and...
