Owie!
/ Owie! #1
BigD23
Platinum Member
Pac. NW
Kubota BX23 TLB
Happens from time to time unfortunately...While attaching my new landscape rake to the new 3pt. hitch on the back of my new (to me) BX23 and while attempting to hook up the tractor end of the new top link, things slipped and were sure to have my left hand pointing finger in between...Fingernail purple doesn't look good on me...Haven't had one like this since I was on the Kitty Hawk, Vietnam, loading 500 pounders...Got it on ice and thought I'd type this before the throbbing starts...Stories to share?
Flat Fingered Don
/ Owie! #2
Grease gloves man! I keep several pairs around, old ,beat, greasey work gloves just to use for mounting 3 point implements!
/ Owie! #3
If the nail does turn purple underneath you can bore or burn a hole in it to relieve pressure. I smashed a thumb good many years ago and was told to make a hole in the nail, I didn't believe it, asked my doctor and he said to do it. I was awake all night with the throbbing thumb, gently bored a hole into the center of the nail with a very small drill bit from a dremel tool. I tell ya it was better than *** when that pressure was relieved:D
Coincidently I have a blood blister on my thumb right by the nail, I got it today releasing a tie down buckle on my trailer. Smacked me hard somehow on the side of the thumb, hurt like crazy but still better than a smashed nail.
/ Owie! #4
Do yourself a favor. Get the Pat's EZ Change system. I think they have a link in the Attachments forum of TBN. For a couple of bucks, it'll:
1. Help in connecting to 3PH attachments when on uneven ground.
2. Extend the length of your 3PH arms about 2 inches, which helps in lifting attachments, like the landscape rake you mentioned in another post.
3. Avoids the dreaded purple thumbnail(s).
/ Owie!
Was looking at Pat's EZ Change and it looks like a much simpler overall way to go...This landscape rake is one awkward thing to juggle around...First time and all with it.
Don
/ Owie!
Usually wear gloves when attaching items to a tractor...The one time I didn't of course...At least it's not my drinking hand.
Don
/ Owie! #8
Flat Fingered Don
Don,
If you don't drill it, there is a good chance you will lose the nail. I don't advocate alchohol, but a couple of shots before I drill seems to help. Courage if nothing else. (Wuss) Depending on how bad it is, they sometime squirt a bit.
Best of luck!!
BD
/ Owie!
Don,
Best of luck!!
BD
Thanks BD...Alcohol is what I was thinking of too...Hope I drill the right finger when I finish the jug.
Don
/ Owie! #10
Working construction in my younger years, I have smashed a few fingers/thumbs in my day. On one memorable occasion I went to the emergency room and the Doctor fixed me up. He heated a straightened out paper clip till the end was red hot, then he placed it on my nail and it instantly melted through the nail and the pressure was released. This is the method I use and I would urge others to try. It does not hurt as much as drilling the nail.
/ Owie!
Good "tip"........Thanks!
Don
/ Owie! #12
I can certainly relate to a mashed finger. A few weeks ago I was moving some rather large landscape rocks from my trailer to the back yard to be used as a retaining wall. I was lifting by hand each rock from the pallet into the loader. I had made about 4 trips to the back yard and was getting tired (one of those hot southern summer days). I decided to just lift the rocks up on edge and drop them into the bucket as this seemed easier. I had leather gloves on, but on one ocassion, I must have had my right little finger resting on the edge of a rock when the one I lifted to let drop into the bucket, dropped right on my finger. I recall hearing a strange noise as it hit. I sure didn't want to take that glove off (was afraind of what I'd see). I did, and sure enough, the finger was dangling and bleeding like a stuck hog. I went into the house put a wet towel on it and considered my options. Only one thing to do. Call wife. Hey hon, can you help me out here? I mashed my little finger. She came home from work early and after about 8 hours later we came home from the emergency room where they had put it back together. Man talk about sore, Still hurts but the doctor said those crushed little pieces of bone will attach back together in time. the nail is what they used as something to sew the other pieces to. Talk about hurt, a week later when they removed the stitches, ouch. Much better now, but I guarantee I'll be more careful next time.
/ Owie! #13
Sam,
I like your idea! A hot paper clip or needle would be sterlized too. I suppose a little RUBBING Alchohol wouldn't hurt no matter what method a guy uses. Ha!
Everybody....BE SAFE!
/ Owie! #14
Hanging sheet rock a couple months ago and hit my left thumb twice. That second time hurt so bad I didn't do it a third time. Course it turned black and kept hurting more each minute. Memory returned about drilling it to reless pressure. Got Dremel bit and by hand drilled a little hole in it. Some blood came out and some relief but not enough. Got bigger Dremel bit and made a little bigger hole. That did it with more blood out. Poured alcohol on it. Should have drilled another hole a little further back to let more blood out but didn't. Nail almost back to normal now. A few years ago I was stapling screen wire on a screened in room I had built and was using an air stapler. Sliding screen under left hand and stapling with right hand. Was really moving along when I realised I had just stapled my middle finger at last joint. No pain. Tips of staple was sticking out front. Thought "I've messed up". Wife came out and showed her and she panicked. She said I was turning quite pale. Sat down and pondered what to do. Dr would just pull it out, ask if I'd had a tetnas? shot in the past 2 years (I had) and put antibiotic on it and give me a big bill. Told my wife to get pliers. She started hollering that she couldn't do it, she couldn't do it, she couldn't do it!!! Told her get me pliers. Grabbed top of staple and pulled quick. It came out as easy as it went in. Still no pain. Poured alcohol on it. Rubbed neosporin on it and put a gauze bandage on it. Then the color started returning to my face.
/ Owie! #15
I've never personally seen anyone drill or burn a hole through a fingernail, but I'll probably never forget one of my wife's brothers telling about his wife burning a hole through one of his. Apparently she went a little deep with a hot needle, and he went straight up in the air.:D But I did see one of the guys on the TV show Deadliest Catch relieve the pressure in a smashed finger that way.
/ Owie! #16
I do this all the time in the ER. It is called trephination. These things hurt so much I usually numb up the finger first before I do it. People can't stand the thought of me coming at them with a cautery when their finger is throbbing that much. Also I don't recommend doing this at home. I have seen people do it with heated paper clips and end up with infections under the nail then the whole thing has to come off.
/ Owie!
Wow.......After reading your story, my finger doesn't seem to hurt as bad.
Don
/ Owie!
These shared stories such as yours makes me think how tough the pioneers and early settlers were...Doing everything by hand...No phones, no immediate 911, no life flights etc.
Don
/ Owie! #19
Around here we refer to these little incidents as TRACTOR BITES! Just like your wife: you love her, but sometimes she bites.
Stuff like that never happens when I am wearing golves, but try to change an implement without gloves and I get bitten.
/ Owie! #20
Don
Yeah but a lot of them didn't live very long either!
