California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,865
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I run a 4 ft rotary mower fine on my YM186D. 240 lbs of suitcase weights on the front helps so when I pull the handle the mower rises, instead of the nose of the tractor.
This mower does work the tractor hard to get it spinning when you let the clutch out. I usually do this with the Powershift in neutral to avoid a stall since these little 3-cylinder Yanmars don't have the low end torque of the 2 cylinder models. After it gets over 2000 rpm there is plenty of power.
I generally mow downhill in third range and uphill in second range - but pictured are two instances where I stopped and shifted to low range. In the first picture it was working too hard. In the second picture, I needed to inch along so I wouldn't run my head into low branches - or, lift the nose of the tractor and set it down crooked, ramming the tree.
