Our foundation getting dug and setup.
/ Our foundation getting dug and setup.
More pics!.
Block work.
Sidewalls.
More wall pics.
More foundation pics.
Another.
Concrete truck for the foundation wall.
Last one for now.
Will post more as things move along!
/ Our foundation getting dug and setup. #49
So, you lay the block, then fill it all with concrete? That's why the rebar is laid in there? Seems like an easy, quick and good way to do this..........
/ Our foundation getting dug and setup. #50
What is the shiney stuff under the block? Is this a metal shield or block? To stop bugs or limit the poured concrete to the upper course, or something else?
</font><font color="blue" class="small">( What is the shiney stuff under the block? Is this a metal shield or block? To stop bugs or limit the poured concrete to the upper course, or something else? )</font>
Code here requires 6" min concrete embedment for the 1/2" anchor bolts to hold the sill plate. The shield is to hold the concrete in place.
#4 Rebar vertical wall reinforcement in fully grouted cells is also required every 4 feet.
/ Our foundation getting dug and setup. #52
I've not seen the rebar on top of the concrete blocks like that. It looks like you have vertical rebar bent over on top and tied into horizontal rebar. That ought to make for one tough wall, especially filled with concrete. Our code here calls for vertical rebar every four feet but nothing on top. Looks good. Keep posting pictures. I find it all very interesting. I'm currently putting in the blocks for my foundation.
Tom
/ Our foundation getting dug and setup. #53
"Code here requires 6" min concrete embedment for the 1/2" anchor bolts to hold the sill plate. The shield is to hold the concrete in place."
Sounds like the block cavities will generally be empty??? Seems it would be nice to fill it all in. We don't use blocks here, just formed stem walls. Anybody know why? With the blocks, a guy could use them as handy forms for the poured mud. We are seeing more ICF jobs than blocks.
</font><font color="blue" class="small">( Sounds like the block cavities will generally be empty??? Seems it would be nice to fill it all in. We don't use blocks here, just formed stem walls. Anybody know why? With the blocks, a guy could use them as handy forms for the poured mud. We are seeing more ICF jobs than blocks. )</font>
The block cavities are all filled, but only the top 6" for the ones holding the sill plate bolts.
I haven't seen any ICF jobs in this area of Florida..... probably because most of the homes are built on slabs, and a few like mine are on crawl spaces.
/ Our foundation getting dug and setup. #55
Full basements are an excellent way (when "walkout" is possible) to greatly expand your total sqaure footage and not have to pay property tax on that footage. Basements are not included when they calculate taxes. At least here in VT. You just finish it off and throw up some shades after they leave /forums/images/graemlins/smile.gif Overall, it's pretty inexpensive square footage regardless of where you live. I'm surprised more people don't do it in the south, especially considering the favorable digging conditions compared to the boulder infested north.
/ Our foundation getting dug and setup. #56
The high underground water levels and humidity down South usually negate basements
/ Our foundation getting dug and setup. #57
What's a basement? /forums/images/graemlins/grin.gif
/ Our foundation getting dug and setup. #58
A basement is one of those things us Northerners go to when hiding from tornados.
Farwell
/ Our foundation getting dug and setup. #59
</font><font color="blue" class="small">( A basement is one of those things us Northerners go to when hiding from tornados.
Farwell )</font>
amen, brother.....here in Tornado alley, we know of which you speak!
In fact, my new house has a "Storm room" built into the design. A 10' X 10' re-inforced concrete room with concrete ceiling and heavy steel doors........
2018 DODGE CHARGER (A66091)
2018 DODGE CHARGER...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
2017 TRAILEZE TE80 HTS LOWBOY (A65057)
2017 TRAILEZE TE80...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2015 Infiniti QX60 (A66738)
2015 Infiniti QX60...
