L5240 is one model in the previous generation of highly regarded Kubota 'Grand L' tractors.
This series was sold prior to imposition of Tier IV emission controls so no Diesel Particulate Filter.
Kubota L5240
2007 - L40 Series
Compact Utility tractor
Previous model: Kubota L5030
Next model: Kubota L5460
Series next: Kubota L5740
Series back: Kubota L5040
Manufacturer: Kubota
Original price (USD): $29,761 (2011)
Variants:
L5240HST: ROPS
L5240HSTC: cab
Kubota L5240 Engine:
Kubota 2.4L 4-cyl diesel
Kubota L5240 Power:
Engine (gross): 54 hp [40.3 kW]
Engine (net): 52 hp [38.8 kW]
PTO (claimed): 45 hp [33.6 kW]
Capacity:
Fuel: 14.3 gal [54.1 L]
Hydraulic system: 11.9 gal [45.0 L]
Front axle: 9.5 qts [9.0 L]
3-Point Hitch:
Rear Type: II/I
Rear lift (at ends): 3,860 lbs [1750 kg]
Rear lift (at 24"/610mm): 2,980 lbs [1351 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@2550
Mid PTO: semi-independent (optional)
Mid RPM: 2000
Dimensions & Tires:
Wheelbase: 75.4 inches [191 cm]
Weight: 3902 to 4233 pounds
Front tire: 9.5-16
Rear tire: 14.9-26
Kubota L5240 attachments:
snowblower
blade
front-end loader
backhoe
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: hydrostatic power steering
Brakes: mechanical wet disc
Cab: Two-post ROPS. Grand CAB on HSTC.
Hydraulics:
Type: open center
Capacity: 11.9 gal [45.0 L]
Valves: 2 to 3
Pump flow: 9.8 gpm [37.1 lpm]
Total flow: 14.7 gpm [55.6 lpm]
Steering flow: 4.9 gpm [18.5 lpm]
Electrical:
Ground: negative
Charging amps: 45
55 (cab)
Battery:
Number: 1
Cold-cranking amps: 582
Volts: 12
Page information:
Last update: November 21, 2014
Copyright: Copyright 2016 TractorData LLC
Contact:
Peter@TractorData.com
