Price Check Opinions please L5240
   / Opinions please L5240 #1
z1069
Dayton, TX
No tractor now use to have Kubota L5240 HST
My neighbor wants to sell his L5240 HST with Modern Ag box blade and Rhino shredder.
It looks good. fluids and filters changed regularly. Im not sure of the age or hours. Pretty sure its several years old
His asking around 20k.
I drove it around for a bit.
Just wondering what you guys thought.
Thanks
Marc
   / Opinions please L5240 #2
L5240 is one model in the previous generation of highly regarded Kubota 'Grand L' tractors.
This series was sold prior to imposition of Tier IV emission controls so no Diesel Particulate Filter.
Kubota L5240
2007 - L40 Series
Compact Utility tractor
Previous model: Kubota L5030
Next model: Kubota L5460
Series next: Kubota L5740
Series back: Kubota L5040
Manufacturer: Kubota
Original price (USD): $29,761 (2011)
Variants:
L5240HST: ROPS
L5240HSTC: cab
Kubota L5240 Engine:
Kubota 2.4L 4-cyl diesel
Kubota L5240 Power:
Engine (gross): 54 hp [40.3 kW]
Engine (net): 52 hp [38.8 kW]
PTO (claimed): 45 hp [33.6 kW]
Capacity:
Fuel: 14.3 gal [54.1 L]
Hydraulic system: 11.9 gal [45.0 L]
Front axle: 9.5 qts [9.0 L]
3-Point Hitch:
Rear Type: II/I
Rear lift (at ends): 3,860 lbs [1750 kg]
Rear lift (at 24"/610mm): 2,980 lbs [1351 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@2550
Mid PTO: semi-independent (optional)
Mid RPM: 2000
Dimensions & Tires:
Wheelbase: 75.4 inches [191 cm]
Weight: 3902 to 4233 pounds
Front tire: 9.5-16
Rear tire: 14.9-26
Kubota L5240 attachments:
snowblower
blade
front-end loader
backhoe
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: hydrostatic power steering
Brakes: mechanical wet disc
Cab: Two-post ROPS. Grand CAB on HSTC.
Hydraulics:
Type: open center
Capacity: 11.9 gal [45.0 L]
Valves: 2 to 3
Pump flow: 9.8 gpm [37.1 lpm]
Total flow: 14.7 gpm [55.6 lpm]
Steering flow: 4.9 gpm [18.5 lpm]
Electrical:
Ground: negative
Charging amps: 45
55 (cab)
Battery:
Number: 1
Cold-cranking amps: 582
Volts: 12
Page information:
Last update: November 21, 2014
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
   / Opinions please L5240 #3
What does location have to do with it? :confused3:
The OP is looking for opinion on the price of the machine of his neighbor. He is not looking for suggestions to get a new tractor.
Back to the question, can't comment on prices over there, but try to know the year and hours of the machine so people here can have a better idea of the machine and help you with the pricing.
And no, we don't really need your location. It's optional, not mandatory.
   / Opinions please L5240 #4
TractorHouse.com is a good place to get a general idea what price others are asking for a particular model of tractor.
   / Opinions please L5240 #5
Open station I'm guessing. No idea on price, but it's not going to there very long. Some including me prefer it over the L6060.
Yes Sir, open station. I did the tratordata and tractorhouse thing before I posted. I guess I was mostly wondering what you guys thought of the l5240.
I never considered a Kubota. I was mostly researching Fords/ New Holland, LS and Mahindras.
   / Opinions please L5240 #7
I look at lots of used tractors and that sounds like a good deal.
   / Opinions please L5240 #8
FYI...
The Grand L 40's have two submodels during their manufacturing run. The newer models are -3 as in L5240-3. They can be differentiated by the earlier version in the way the PTO engages. The -3 models will use an electrical rotary switch to engage the PTO, while earlier versions will use a manual lever. If you purchase the tractor, you'll need to know which version when purchasing replacement parts in some cases.
I believe the -3 models were offered in 2010.
Does the tractor in question have a FEL?
Good luck!
   / Opinions please L5240 #9
A tier 3 52 hp Kubota.
With implements included in the deal
Well maintained
$20k
What’s not to like there? Assuming the sheet metal is good, and it comes with a fel.
   / Opinions please L5240 #10
NEW Wolverine Skid Steer Trencher (A59000)
NEW Wolverine Skid...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
2020 DRAGON ESP...
2002 Ford F-650 Landscape Flatbed Truck (A56858)
2002 Ford F-650...
2008 Dodge Ram 1500 Pickup Truck (A55973)
2008 Dodge Ram...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
