oops!!! left the key on.
/ oops!!! left the key on. #1
jmunn
corry. pa
john deer 4110
Oops left the key on my 4110. Did I hurt the glow plugs? Left it on for about an hr.
/ oops!!! left the key on. #2
Do the glow plugs operate with the key, in any setting?? On my tractor they only work in one spring-loaded position? when released it goes back to ON... If you held the plugs on for an hour????
/ oops!!! left the key on. #3
On my 3720 you have to turn the key and push it in and hold it to operate glow plugs.
/ oops!!! left the key on. #4
nope.. no damage to glow plugs done.
Worst is maybe the hour meter ran up some time or battery lost some charge.
You should not worry.
/ oops!!! left the key on. #5
The plugs only operate for a small number of seconds. Your fuel solenoid was on but it also would be if it were running. You did no harm.
/ oops!!! left the key on. #6
Manual implies the glow plugs shut themselves off, and you hear a click when they go off (likely the relay) in about 3 seconds.
/ oops!!! left the key on. #7
There is no GP timer on these tractors. They are ONLY active while the key is held in the start position, that is why it helps to put the range selector in gear or pull the PTO knob up and try to start it first on really cold days, it helps starting so much more. The 4100, 2210's and I think the 2305's are all the same way. Hour meter is mechanical so no harm dome there either.
Thanks for the help guys!!!
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
Single Cedar Glider (A65583)
Single Cedar...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
New 215/50-10 NHS tire on 5-lug John Deere compact tractor rim, Coal Valley, IL (A65640)
New 215/50-10 NHS...
