oops!!! left the key on.
/ oops!!! left the key on. #1
jmunn
corry. pa
john deer 4110
Oops left the key on my 4110. Did I hurt the glow plugs? Left it on for about an hr.
/ oops!!! left the key on. #2
Do the glow plugs operate with the key, in any setting?? On my tractor they only work in one spring-loaded position? when released it goes back to ON... If you held the plugs on for an hour????
/ oops!!! left the key on. #3
On my 3720 you have to turn the key and push it in and hold it to operate glow plugs.
/ oops!!! left the key on. #4
nope.. no damage to glow plugs done.
Worst is maybe the hour meter ran up some time or battery lost some charge.
You should not worry.
/ oops!!! left the key on. #5
The plugs only operate for a small number of seconds. Your fuel solenoid was on but it also would be if it were running. You did no harm.
/ oops!!! left the key on. #6
Manual implies the glow plugs shut themselves off, and you hear a click when they go off (likely the relay) in about 3 seconds.
/ oops!!! left the key on. #7
There is no GP timer on these tractors. They are ONLY active while the key is held in the start position, that is why it helps to put the range selector in gear or pull the PTO knob up and try to start it first on really cold days, it helps starting so much more. The 4100, 2210's and I think the 2305's are all the same way. Hour meter is mechanical so no harm dome there either.
Thanks for the help guys!!!
2019 HYDREMA MX18 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX18...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
E-Z Trail 3400 Gravity Wagon (A66285)
E-Z Trail 3400...
2018 VOLVO VNL 670 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 670...
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
