one more hydraulic question
/ one more hydraulic question #21
What a perfect T&T valve this is:Surplus Center Item Detail!
I'm taking it that the 17+" dimension shown for it is the height from bottom to top of handle, correct?
/ one more hydraulic question #22
I am sure the 17" inludes the handle-but they are very helpful on the phone if you call them.
/ one more hydraulic question #23
Ron & Mike, for this application, the B2910 is just like my B2710 and you do not need power beyond or a 7th hose to return to sump. You can see a picture of the valve I used in the photo section of TBN here. You can see the two hoses going down inside the fender which go to the hydraulic outlet that's been discussed. The four hoses going to and from the two cylinders are connected on top of the valve and you can also see those 4 hoses here. Six hoses total.
/ one more hydraulic question #24
This has been an interesting thread.. Another newbie here that is looking into getting remotes.
I was thinking of getting a 3 spool valve. Two for TNT and one for ?? Considering I didn't think I "needed" remotes - figured I would add a third spool.
Silly question. The valve above has only one joystick but two spools. does this work just like a loader valve - vertical and horizontal for the two different work ports?
/ one more hydraulic question #25
Yes it does, left-right is one spool, front-back(up/down) works the other.
/ one more hydraulic question #26
I'm getting closer, but now I would like opinions on the size of cylinders to order.
Here is one spec for side link:
SPECIFICATIONS Double Acting
Bore/Stroke 1" x 4"
1500 PSI working pressure
Rod dia 1/2"
  • Ports 1/4" NPT
  • Retracted Length 10 1/2"
  • Shpg 6 lbs
END MOUNTINGS
  • Rod End Clevis
  • Pin holes 1/2"
  • Outside Ears 1"
  • Inside Ears 1/2"
  • Throat Depth 1"
  • Base End Clevis
  • Pin holes 1/2"
  • Outside Ears 1"
  • Inside Ears 1/2"
  • Throat Depth 1"
Is this heavy duty enough for side link?
I am considering this one for top link, What's your ideas on this choice?
SPECIFICATIONS Double acting
Bore x stroke 1-1/2" x 14"
PSI max. 3,000 Rod dia. 1"
  • Ports SAE 6
  • Retracted length 21-1/4"
  • Shpg. 12 lbs.
END MOUNTINGS
  • Rod end swivel-ball
  • Ball width 1"
  • Ball O.D. 2"
  • Pin hole 0.75"
  • Base end swivel-ball
  • Ball width 1"
  • Ball O.D. 2"
  • Pin hole 0.75"
Should I be looking for 3000 psi and 1" Rod dia on both
OR would 1500 psi and 1/2 " dia be satisfactory?
I do appreciate all replys so let em rip.
/ one more hydraulic question #27
If it were me I would definitely be looking at minimum Ø1" rods or larger for the side links. The top link is OK IMO. As far as the pressure rating, what is your tractor's system. You want to match or exceed that.
/ one more hydraulic question #28
What Rob said... The side links can come under considerable pressure and a small rod may fold up when you turn the wheel and push that box blade sideways across the ground with a load of soil in it.
/ one more hydraulic question #29
I am asking thie question just to see if I am understanding some of what I have read on this site. If I wish to hook up a hydraulic thumb to my BH would I have the return line from my BH, which brings the fluid back to the tractor, go to the valve for the thumb then the line go from the thumb back to where the return line would have hooked up to bring the fluid back to the tractor.
Now that valve that the return line is connected to should allow the fluid to run freely until the thumb is needed. Then the fluid will be redirected by the valve up to the ram to open or close the ram then the fluid going back and continuing back to the tractors resevoir .
Sounds simplistic but is this how it works? My tractor is a B2630 model year 2006.
Is that valve one which sits upright and if moved one way the ram opens and if moved the other way the ram closes ,unsure as to the technical name for the valve
/ one more hydraulic question #30
That would be a single spool open center valve, 3 position, spring centered to neutral. Your grasp of how it works is correct, but it depends a lot on the hoe valve capabilities and how your hoe valve is plummed into the system. Most valves with just a single input and return line as you have described are not rated for much pressure on that return line. It is typically supposed to take a low restriction path back to the reservoir. By putting a valve on that return line, you could cause excessive back pressure to parts of the main hoe valve and do damage to it(usually spool "O" rings).
A place where you could put your single spool valve would be on the input line. This side is rated for high pressure. You would need a single spool valve with "Power Beyond". Power Beyond is simply a high pressure path thru a valve from the high pressure inlet. A power beyond valve has 3 main lines. A high pressure Supply inlet, A High pressure PB outlet and a low pressure return. The return line is the fluid comming back from a moving cylinder or from the relief. Any back pressure on this line reduces the force applied by the cylinders so it must be a unrestricted outlet to the reservoir.
The input that now feeds your hoe valve would instead go to the new single spool inlet. The hoe valve input would then be connected to the PB outlet of the single spool. The Return line could be "T" d into the hoe valve output providing it is a low pressure return to the tank.
Another option, depending on your valve make, might be to get another section for your hoe valve and add another spool/lever to the stack for this function.
Yet Another option would be to get either a manual or electric dual selector valve. Surplus Center Item Detail This valve has 6 ports. 2 connect to the work ports on your hoe valve. 2 connect to the cylinder that used to be connected to the hoe valve where we connected the first 2 ports. The last 2 go to the new cylinder. This would allow one of your existing functions, such as one of the outrigger arm levers, to switch functions with a simple lever movement and function as the thumb control untill switched back.
You might get more answers if you start this as a new topic in the hydraulics forum.
2018 FORD F-150 (A60736)
2018 FORD F-150...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
Toro Timecutter Max (A61166)
Toro Timecutter...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
2018 Chevrolet Trax SUV (A61569)
2018 Chevrolet...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
