? on proper install of wall in area subject to freeze - base preparation?
   / ? on proper install of wall in area subject to freeze - base preparation? #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I'm wondering if anybody here might have some suggestions on how to do this properly.
First off - I live in MA, so the reason why I'm asking this question is because I want to make sure I do the install properly to avoid freezing damage.
Second: I understand the basic rules for installing stuff around here to avoid frost heaving : the base must go down below the frost line
but - I guess I'm sort of confused because I see some things around here built with no real base that goes below the frost line - but they do last for decades without being destroyed by the winters. Stone walls and granite curbing along the streets being two of the most common ones.
The project: I acquired a stock of what was supposed to be granite curbing (odds and ends) - from a local quarry that was going out of business. What I want to use them for is to build a short retaining wall (no higher than about 2ft high exposed at it's highest part) - along the back part of my property line so I can then raise the grade of my back yard and make it more level.
This wall will start at about 2ft high - run for about 75ft or so and end flush with grade. The blocks are about 3ft long x 12 to 18 inches high. Along the highest part of the wall I will stack them two high - and I've gotten a number of recommendations from stoneworkers and masons about how to bond the stacked blocks together, with the most common recommendation being to use some of the new epoxies that are out there.
Behind this I would then backfill the yard up to level of the top of the new wall.
To prevent the pressure from the backfill eventually toppling the wall - I was planning on building up some concrete on a taper (thinner at the top wider at the base) behind the granite blocks to keep the pressure from the ground being able to eventually topple the blocks. I was thinking some sort of waterproof barrier along the face of this concrete would help prevent water intrusion and the freeze/thaw cycle destroying the thing eventually.
My biggest question is: what should I be doing for a base under all of this? I ask about granite curbing installs - because every one I've seen around here basically just lays the curbing down in a concrete base maybe 6 inches thick - the curbing itself extends maybe 12" below grade if you're lucky - so there's no way the base under the curbing extends below the frost line. I see the same thing with stone walls built around here. They typically only go below ground a foot or maybe two if they guy doing the wall wants to spend a lot of money.
Do I just have to get down deep enough to get below the organic layers of soil and that should be good enough? I know there's a nice hard layer of packed hard sandy gravel/clay (no organics at all) - about a foot and half down on this property. The topsoil and the layer directly underneath (that has some organics in it) - is probably a foot to two feet deep.
Dig up the organics - put down a base of 3" trap rock or something like that - and just put the wall on top of that?
   / ? on proper install of wall in area subject to freeze - base preparation? #2
Dig up top soil, put in a draining base of crushed rock - they call it "class 5" around here but it is something like <3/4" crushed limestone with fines (or local equivalent used for road bases/driveways). Compact and level as needed to grade, but make sure you compact in lifts of no more than 3-4". At least 6" total would be good (fill half, compact, fill the rest, compact again). I did that for my retaining wall 15+ years ago and it has been rock stable and dead level ever since.
   / ? on proper install of wall in area subject to freeze - base preparation? #3
Rock walls with their base above the frost line probably do move with the frost heave in many cases. I think a lot depends on how exposed they are, good snow cover or not, grass, leaves, etc. My driveway is good deep stone, but in winter it heaves a good 6-8 inches. I know this because in summer it slopes down from the garage door, in winter it slopes down to the garage door. Running water doesn't lie. :laughing:
I'm pretty sure if a rock wall was laid on that driveway, which is compacted as good as you will get, it would be riding along up and down with the frost.
My understanding, from reading stone work books, is there is a rule of thumb to follow: Dry-stacked walls (no mortar) can be above the frost depth, they will move and shift a bit, but if well laid will not fall apart. Walls with mortar should be on a base that is below frost depth because any shifting will crack the mortar joints. Some people use a Portland cement, sand and lime mortar. The lime is supposed to be less rigid than cement alone.
I've built a few dry-stacked walls -- with dirt and stone bases -- and they seem to weather the frost heaves okay. Never tried a mortared wall. I'm not sure how the epoxy will react to heaving, it may have some flex to it. Probably a lot has to do with how much pressure the slope behind the wall exerts. For a two foot high wall, it seems like it wouldn't be much.
   / ? on proper install of wall in area subject to freeze - base preparation? #4
Good drainage (3/4"+ stone with no dust) under & behind the wall. 12" under & behind, but the more the better. This does 2 things, obviously the stone will not hold water & heave, and the stone is sort of an insulator not allowing the cold exposed granite to act as a "heat sink" type of thing removing the warmth from the ground & sending the cold from the granite down into the earth. It sounds whaky, but if you want to be sure, but 2" of ridgid foam under the wall and a little under finished grade, extending out to the exposed side of the wall a foot or more. This will keep the frost out for sure. I'd spend the money on the foam instead of some type of epoxy glue.
   / ? on proper install of wall in area subject to freeze - base preparation? #5
Thanks for all the responses guys.
Davedj1: I was actually looking at some Allan Block products just last week for another wall I want to put up - and I plan on using some geogrid on that - so I should probably think of using the geogrid to help tie this wall in also.
I was also planning on sinking the first course into the ground about 4-6 inches.
Rustyiron:
I'm attaching an image I put together to see if I understand what you're saying correctly.
I've heard of using the pink rigid foam along "frost slabs" to keep them from freezing underneath - I guess I never thought of using it for a wall also.
Legend for the image:
grey blocks are the granite curbs I'll be using for the wall.
green is the grass layer
brown is the layer of topsoil
red is the geogrid tying the wall back to the soil behind it
the grey/yellow dots are 3/4 stone
pink is the 2" foam
the yellowish color is the lower soil layer(s) (under the topsoil)
   / ? on proper install of wall in area subject to freeze - base preparation? #7
You don't need the insulation. With a proper compacted base and free draining backfill (better with a path to daylight or drain tile, but probably not needed for a wall this small), you will be fine. Besides - the face of the wall is uninsulated, so what will it actually do? Heat will travel the path of least resistance...
I wasn't sure how insulation would make too much of a difference in this case - it's been my experience that without something that's a higher temp on one side of that insulation - that sooner or later everthing it is going to normalize - and freeze up.
I've seen some setups where - instead of using a full foundation in an area where the ground freezes - they use a "frost slab" ( I believe that is the correct term) - where the slab has insulation alongside it - and going out away from it under the ground. This is supposed to keep the ground underneath the slab from freezing and therefore avoids the necessity for a full foundation in ground that freezes down to a certain depth.
I honestly don't see what kind of a difference this makes - unless - you have a heated building on that slap that keeps the cold from migrating thru the building into the slab and then into the ground below it.
Which would be the case with a wall like the one I'm looking to build. The cold is going to freeze the ground sooner or later anyway around that insulation.
I think I can have a path to drain to daylight on this - so here's a revised (crude) - picture of how the wall would look in cross section. The blue is the drain pipe. The base would be compacted with a compactor - wrapped in filter fabric to avoid silt intrusion - as would the drain pipe.
   / ? on proper install of wall in area subject to freeze - base preparation? #9
Yep, that would be the normal way to do it properly, at least around here. Here is the reference on what you are thinking about for insulated slabs. Frost-protected shallow footings is the technical name... If you read through it, you will see how and why it works, and for both heated and unheated slabs.
View attachment Frost protected shallow footing guide.pdf
   / ? on proper install of wall in area subject to freeze - base preparation? #10
Hi Jim,
Interesting project - I have done similar here - got 300' of granite curbing and built a single high simple retaining wall for raised beds on a slope up to a stone wall at the front of our place. I used 3" or so 3/4 stone and tamped as the base - as I usually do build dry stack walls.
The concern I have about your project is stacking the curbing, adhesive degrading over time, and how to hold it together with the freeze/thaw cycles we have.
I would slope the blocks 10* or so back into the banking and also offset the second row maybe an 1" or so from the bottom row.
How to hold the top from pushing out may be a challenge too. Possibly a lag and an eye in each block connected to the geo grid material? That's a bit of hammer drilling in 20-25 blocks.
Just my thoughts and keep us posted with pics of course!
Carl
Hi Jim,
Carl
The stacking thing was the part that concerned me the most too.
That's why I'm asking the questions - I figured I get some more varied opinions about how to properly install this so I'm not "fixing" it at some point down the road.
One of my thoughts on how to avoid the upper stacked layer falling over was to do something like this:
Light grey = the granite blocks
brown = topsoil
red line = Geogrid
blue circle = drain pipe
dark grey = concrete
light green = waterproof sheet or membrane
dots = 3/4 stone
basically what I'd do is pour both put down a sheet of geogrid low down to tie the wall back to the soil, then I'd put poured concrete behind the granite wall blocks as a further reinforcement to the wall - to keep the pressure of the soil from pushing it over. On the side of the concrete facing the soil - I could put either a sheet of water proofing - or something like Grace Bituthene (concrete foundation waterproofing membrane) to keep the water from penetrating into the concrete from the ground behind.
I didn't show it in the picture properl - but I could lean the stacked granite curb pieces back at some angle to help hold them in place.
   / ? on proper install of wall in area subject to freeze - base preparation? #12
To be honest, when you started this thread, I thought you intended to stack the curbing on the flat sides, not the narrow edges. I don't have a lot of faith in the stability of the two stacked on edge, they are how thick .. 6" or so? They are heavy, but over time I would be worried. I think that is why Carl (I think) suggested the 10* slant and 1" setback.
The solution with the concrete is really more like putting a stone veneer on a concrete wall, than building a stacked stone wall.
   / ? on proper install of wall in area subject to freeze - base preparation? #13
Rustyiron:
pink is the 2" foam
This is what I meant except the foam at the lower grade being placed (to the left) of the wall, out where the cold is, under the wall is ok but I don't think it's necessary. Now this method is the extreme "fix" in poorly drained soils & conditions. Your 2nd (without the foam) drawing is fine for most situations. I also envisioned you stacking in the flat dimension, I would guess that stepping back & leaning in along with the geo fabric will be ok but place greater importance on minimizing the ground "push" by means of a generous overdig with the stone backfill. Looks like a nice job, be sure to take some pics! You might check with local contractors that do this type of work for advice on the stone "footing". You mention compacting it and that suggests a stone with dust material, a loose, stone only (3/4-1") base that will not hold water is what I would use. You are not supporting/distributing much weight, like if you were building a house on it. Your concern is drainage
   / ? on proper install of wall in area subject to freeze - base preparation? #15
This is what i would do. Sorry for the poor picture but i think you'll get my point.
1) Remove all organic material under wall
2) Provide for 6" of 3/4" process compacted base , Do not use stone only. The reason you do not use stone only is because stone is meant to collect the water.
3) I would set first stone at least 6" below finish grade.
4)Tilt stone back alittle
5) Set second stone
6) Install 4" perf. pipe draining to daylight. "black circle in picture"
7)Backfill with stone 3/4" or like size "what ever is cheapest" Red area in picture
8)Install landscape fabric "yellow line in picture"
9) Backfill wall
Just a few notes. In my book you can or can not use the geo-grid thats your choice.
The only time you would use stone only under the wall is if you have a perf. pipe draining to daylight to collect and remove the water otherwise using process is the way to go as it will not collect the water like stone will. If you plan on bonding your top and bottom stone together with whatever product you select make sure it is flexible otherwise it won't work. The main problem i see with the way you are building the wall is the way i think your are thinking of laying the stone. As with retaining wall blocks when they are dry-stacked they have a way of locking the backs of the stone so they won't slide forward. If you layed the blocks flat i would say no problem at all but laying them on edge will make them top heavy and thats not what you want.
Again this is what i would do and as with everything else everyone has there own way of doing things. One more thing i would like to add and it would be alot of work. With the way you are stacking your stone the only way i would do it is if you had a hammer drill and pinned your top stone to the bottom stone then i would say have at it your good to go."Green Pin in Picture
The pieces of granite I using are from a quarry that closed and had bargain basement pricing on pieces of curbstone and other processed granite pieces. The pieces are roughly 3 feet long, 16-20 inches high (they're not all the same) - and 6-7 inches thick. I know what you mean about laying them down - that would be the "easy" way to build the wall - the mass of the wall itself would probably hold it in place if I was to build like that. This probably compounds matters some but what would the top and bottom faces of these blocks are very smooth - the "face" that I want to show is rough hewn and I think will make a nice looking wall once the blocks are stacked. My thought was that the fact that I've got some smooth faces means that if I can lay these right - I can get a wall with a look of some nicely fitted granite blocks.
I'm looking for the best way to make it all hold together if I can.
I'll see if I can get some pics of the granite blocks I'm going to be using - that might help give a clearer picture.
I took a quick look at the frost protected shallow footing guide that dstig1 posted a link to in a previous response just to refresh my memory on what I thought I recalled about that subject. I understand what you're saying about placing the foam out to the left - extending out to where the frost is, my problem with that in this particular installation - is that the wall is going to be right along a property line - so extending the foam out to the left would entail either A) setting wall a few feet back from the property line , - or - B) asking the neighbor for permission to dig up his lawn.
I don't really want to do A , and I don't think the neighbor would go for B.
5) Set second stone
9) Backfill wall
The picture is fine - it's clear enough to get the point across.
So - for the compacted base you show in your picture - are you saying to NOT use just 3/4" stone? I used a product the Co. I got it from called "graded base" as the top layer on my driveway. The stuff is basically a rock dust 3/4 stone mix. It compacts GREAT. I've had it down for about 5 years now and I can have cement trucks drive across it and barely leave a tire track.
Do you think that would be a better base for the wall?
   / ? on proper install of wall in area subject to freeze - base preparation? #18
Do you think that would be a better base for the wall?[/QUOTE]
Correct you do not want to use just stone as that will collect water. You want to use something that will compact, size of material really doesn't matter but in your case i wouldn't go with anything that is over 1 1/2". Your process will consist of material from stone dust up to what ever size you request lets say 3/4". That should work fine as your wall base. If 1 1/4" process is cheaper go with that. They don't use large stone process under an asphalt driveway but for your wall you could use something larger. Like i said whatever is cheaper.
   / ? on proper install of wall in area subject to freeze - base preparation? #19
Jim,
BuilderML diagram is what I was referring setback the top block and slope 10* or so. Just some other thoughts on the pinning of the block.
Lay your first course, then run a line from one end to the other if its not straight put a pin between the blocks to guide the line, then drill 1/4"or 3/8" holes 1-2" back along the tops of the first row say two or three holes/block. Then insert SST pins so they stick up a 1/2" or so.
Then maybe some galvanized fence sections on top of the pins 18" or so back into the grade to act as the dead man. Some stone dust/concrete mortar mix on this and some concrete behind the wall and let it set up. Then set the second course blocks up against the SST pins and on top of the fencing. I suggest SST otherwise you will have rusty wall stains in a few years.
These blocks are heavy and unwieldy at 3' long and I find it easiest to get them close with the BH and thumb, then final positioning with pry bars.
Jim,
I'm having a hard time visualizing what you're describing. Are you saying the pins are there to give the galvanized fencing something to grab onto?
(1) 48"X18' ADS DRAINAGE PIPE (A60432)
(1) 48"X18' ADS...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
PALLET OF (5) INDOOR CABINETS (A60432)
PALLET OF (5)...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
John Deere 5055E (A53317)
John Deere 5055E...
2022 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A60429)
2022 BOMAG...
